GDAL
July 26, 2018, 8:27pm
1
#3607: Removing map layer crashes wxGUI
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 7.4.0
Keywords: remove layer, layer manager | CPU: OSX/Intel
Platform: MacOSX |
If you try to remove a raster or vector map from the layer manager, using
the "remove" option in the popup list launched by the button on the right
side of the layer, it will crash the entire GUI with the following error:
/Applications/GRASS-7.5.app/Contents/Resources/bin/pythonw: line 3: 25590
Segmentation fault: 11
/Applications/GRASS-7.5.app/Contents/Resources/python.app/Contents/MacOS/python
This error and behavior is similar to those reported in #3472 and #3487 .
This was reported to me for v. 7.4.0 but also occurs in the most recent
trunk (r73007)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
October 2, 2018, 6:36pm
2
Priority: normal | Milestone: 7.4.2
Resolution: | Keywords: remove layer, layer manager
CPU: OSX/Intel | Platform: MacOSX
Changes (by cmbarton):
* milestone: => 7.4.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:1> ;
GDAL
October 3, 2018, 1:35am
3
Comment (by annakrat):
I can't test myself now, but this seems weird. Does this happen every
time? Do you have at the same time vector digitizer or 3D view on?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:2> ;
GDAL
October 3, 2018, 1:42am
4
Comment (by cmbarton):
Every time, but only if removed in this way. All other remove methods work
fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:3> ;
GDAL
March 4, 2020, 9:34am
5
Priority: normal | Milestone: 7.4.5
Comment (by nila):
This is still an issue with 7.8 branch and master (7.9.dev), with Python
3.8.2 and wxPython 4.0.7.post2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:7> ;
GDAL
March 4, 2020, 2:24pm
6
Just to make it clear, do you have to press the button to crash, or also
right click (or whatever you use on mac) would do it as well?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:8> ;
GDAL
March 4, 2020, 2:42pm
7
Comment (by nila):
Yes, this only crashes when removing layer from button-menu.
But **not** from contextual menu (right click), where it works as
expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:9> ;
GDAL
March 12, 2020, 7:09pm
8
Changes (by nila):
* Attachment "3607_debug_log_2020-03-12.txt" added.
backtrace log up to crash
GDAL
March 12, 2020, 7:42pm
9
Comment (by nila):
I managed to find the cause of this bug (see attachment above). In short:
1. clicking the button triggers an event with the `GenBitmapButton`
embedded
2. the layer (`TreeItem`) is deleted (`GMFrame::OnDeleteLayer()`) and with
it the included button (the same as in the event)
3. further event handling (in `wx.lib.buttons.GenButton::OnLeftUp()`)
deals with a still living python object with a
"wrapped C/C++ object of type `GenBitmapButton` has been deleted"
I couldn't find a quick fix for this, but I'll try to come up with a
solution.
Still, if someone more experienced is up to the challenge to address this
I'd be more than happy.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:10> ;
GDAL
March 26, 2020, 1:06am
10
Thanks for the detailed analysis. I can't test but this might work:
diff --git a/gui/wxpython/lmgr/layertree.py
b/gui/wxpython/lmgr/layertree.py
index 52c20dcc0..b2b39c613 100644
--- a/gui/wxpython/lmgr/layertree.py
+++ b/gui/wxpython/lmgr/layertree.py
@@ -421,7 +421,7 @@ class LayerTree(treemixin.DragAndDrop,
CT.CustomTreeCtrl):
# select the layer in the same way as right click
if not self.IsSelected(layer):
self.DoSelectItem(layer, True, False)
- self.OnLayerContextMenu(event)
+ wx.CallAfter(self.OnLayerContextMenu, event)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:11> ;
GDAL
March 26, 2020, 7:52am
11
Priority: normal | Milestone: 7.8.3
Component: wxGUI | Version: git-releasebranch78
Changes (by neteler):
* version: 7.4.0 => git-releasebranch78
* milestone: 7.4.5 => 7.8.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:12> ;
GDAL
March 26, 2020, 10:57am
12
Comment (by nila):
Replying to [comment:11 annakrat]:
CT.CustomTreeCtrl):
Brilliant, it works fine, thanks!
Will you put up a PR?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:13> ;
GDAL
March 27, 2020, 1:14am
13
Sure: https://github.com/OSGeo/grass/pull/462
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:14> ;
GDAL
March 27, 2020, 9:08pm
14
Type: defect | Status: closed
Resolution: fixed | Keywords: remove layer, layer manager
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Merged to master and 78.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607#comment:15> ;
