[GRASS-dev] [GRASS GIS] #3616: selecting location and mapset selections from pulldowns do not register in GUI
GUI
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: unspecified
Keywords: v.proj | CPU: Unspecified
Platform: Unspecified |
If you try to select location and mapset from the pull-down control, it
puts the proper values into the text box. But these do not register to
build the v.proj command. You can see this in the command being built at
the bottom of the GUI window.
Because of this picking the input map does not find a list of maps to
display. And if you type the name of the map into the input box, the
command still fails.
You must manually type the name of the location and mapset into their text
boxes for this to work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616&gt;
GUI
Resolution: | Keywords: v.proj
Changes (by cmbarton):
* Attachment "r-proj_v-proj_bug.jpg" added.
annotated screenshot showing bug that affects both r.proj and v.proj
GUI
Comment (by cmbarton):
I've attached a screenshot showing the problem with an example from r.proj
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616#comment:1&gt;
GUI
  Priority: normal | Milestone: 7.2.4
Component: wxGUI | Version: 7.4.1
* version: unspecified => 7.4.1
* milestone: => 7.2.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616#comment:2&gt;
GUI
  Priority: normal | Milestone: 7.4.5
Changes (by sbl):
* milestone: 7.2.4 => 7.4.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616#comment:3&gt;
GUI
Comment (by nila):
This issue is a duplicate of #3502 (where the cause of the problem is
described) and may be closed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616#comment:4&gt;
GUI
      Type: defect | Status: closed
Resolution: duplicate | Keywords: v.proj
Changes (by neteler):
* status: new => closed
* resolution: => duplicate
Ticket URL: <https://trac.osgeo.org/grass/ticket/3616#comment:5&gt;
