[GRASS-dev] [GRASS GIS] #3617: save display to image button broken
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.4.2
Component: wxGUI | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
The save display to image button is now broken in GRASS 7.4.1 and up. It
works in 7.2.2.
It produces the following error:
   File "/Applications/GRASS-7.5.app/Contents/Resources/gui/w
xpython/mapdisp/frame.py", line 626, in SaveToFile
filetype, ltype = self._prepareSaveToFile()
xpython/mapdisp/frame.py", line 802, in _prepareSaveToFile
filetype, ltype = GetImageHandlers(img)
xpython/gui_core/dialogs.py", line 1834, in GetImageHandlers
for h in image.GetHandlers():
AttributeError
'Image' object has no attribute 'GetHandlers'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617&gt;
Resolution: | Keywords:
Comment (by cmbarton):
Because the cartographic composer doesn't work either in 7.4.1 and above,
I'm escalating this to blocker because there is no way to get a map image
out of GRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:1&gt;
  Priority: blocker | Milestone: 7.4.2
Changes (by cmbarton):
* priority: major => blocker
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:2&gt;
Description changed by neteler:
Old description:
works in 7.2.2.
AttributeError
New description:
works in 7.2.2.
AttributeError
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:3&gt;
Comment (by neteler):
The function `def GetImageHandlers(image):` in
gui/wxpython/gui_core/dialogs.py is identical between 7.2 and 7.5...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:4&gt;
I've tested on a couple of different machines and get the same results.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:5&gt;
Comment (by annakrat):
The problem happens only with wxPython4, the method is simply not there.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:6&gt;
there must be some kind of method for spacing. Is it using a different
one? Is it needed in this case?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:7&gt;
Changes (by veroandreo):
* Attachment "grass7.4_doutfile_3.png" added.
Full error message from d.out.file in GRASS 7.4.1 run in a Mac os sierra
10.12.6 (contributed by Carol Garzon)
Comment (by veroandreo):
I have just attached the full error message obtained when trying to save a
map display in GRASS GIS 7.4.1 from a Mac OS Sierra 10.12.6 (hope it is
readable). The screenshot was kindly contributed by Carol Garzon, she has
tested both from GUI and CLI with same results. She confirms the error was
not there in GRASS 7.4.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:8&gt;
Just in case the message is not readable from the image, here's the ascii
text provided by Carol Garzon:
GRASS 7.4.1 (panamania):~ > d.mon wx1
GRASS 7.4.1 (panamania):~ > d.vect Bufpuntos
d.vect completo.
GRASS 7.4.1 (panamania):~ > d.out.file output=intento format=png
GRASS 7.4.1 (panamania):~ > Traceback (most recent call last):
   File "/Applications/GRASS-7.4.1.app/Contents/Resources/lib/python2.7
/site-packages/wx/core.py", line 2158, in Notify
     self.notify()
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/mapdisp/main.py",
line 590, in watcher
     self.mapFrm.GetMap().GetLayersFromCmdFile()
   File
line 137, in GetLayersFromCmdFile
     self.saveToFile.emit(cmd=utils.split(dCmd))
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/signal.py",
line 229, in emit
     dispatcher.send(signal=self, *args, **kwargs)
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/dispatcher.py",
line 349, in send
     **named
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/robustapply.py",
line 60, in robustApply
     return receiver(*arguments, **named)
   File
line 548, in <lambda>
     self.Map.saveToFile.connect(lambda cmd: self.mapFrm.DOutFile(cmd))
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/mapdisp/frame.py",
line 667, in DOutFile
   File
   File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/gui_core/dialogs.py",
line 1832, in GetImageHandlers
AttributeError: 'Image' object has no attribute 'GetHandlers'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:9&gt;
This might be very easy to fix it.
I just found out that in the same version of trunk where save output does
not work for 2D, it works fine for 3D. We just need to use the 3D code
(and add some additional output formats) for this to work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"73231" 73231]:
#!CommitTicketReference repository="" revision="73231"
wxGUI: wx4 doesn't have Image.GetHandlers, fixes #3617
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:11&gt;
In [changeset:"73232" 73232]:
#!CommitTicketReference repository="" revision="73232"
wxGUI: wx4 doesn't have Image.GetHandlers, fixes #3617 (merged from
releasbranch 76)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:12&gt;
      Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
Sadly, this is still not fixed. The dialog now appears and you can select
a file name and place to save it. But when you click save, it sits
endlessly saying "please wait, exporting image". Nothing is being written.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:13&gt;
Try r73323.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:14&gt;
* status: reopened => closed
Comment:
Yes. This is fixed now. Thanks!!!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:15&gt;
Backported to 7.6 and 7.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:16&gt;
