#3627: i.group: file= parameter for input desired
Reporter: neteler | Owner: grass-dev@…
Priority: normal | Milestone: 7.6.0
Component: Imagery | Version: 7.4.0
Keywords: i.group | CPU: Unspecified
Platform: All |
To enter the input to i.group can reach a significant number of map names.
On Unix like systems backticks can be used to feed in g.list output with
regex/wildcard search. However, this fails on Windows. Here the file
parameter would be handy:
# r.series example, also works on Windows as no backticks involved
g.list rast pattern="tmean.1981_2010.*.avg"
output=list_tmean_1981_2010.csv
r.series file=list_tmean_1981_2010.csv ...
Wish: add a "file" parameter to i.group is it exists for r.series and
other commands.
Resolution: | Keywords: i.group
CPU: Unspecified | Platform: All
Comment (by hellik):
Replying to [ticket:3627 neteler]:
names.
other commands.
not as elegant in linux, but you can do something similar in windows too
e.g. in the winGRASS command line:
:\>FOR /F %c in ('g.list "type=raster" "pattern=*2" "mapset=user1"
"separator=comma"') DO SET RASTER2REMOVE=%c
C:\>SET RASTER2REMOVE=b172,d172,it172,r172
C:\>echo %RASTER2REMOVE%
C:\>g.remove type=raster name=%RASTER2REMOVE%
The following data base element files would be deleted:
raster/b172@user1
raster/d172@user1
raster/it172@user1
raster/r172@user1
WARNING: Nothing removed. You must use the force flag (-f) to actually
remove them. Exiting.
Comment (by mmetz):
Replying to [comment:2 neteler]:
> Replying to [comment:1 mmetz]:
> > Please try trunk r73147
> Works like a charm, thanks! I'd be happy to see that backported since
7.4 will be used by many (Windows) users for a while...
