GDAL
August 27, 2018, 5:37pm
1
#3629: cannot click to check/uncheck accessible mapsets in g.mapsets
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: svn-trunk
Keywords: g.mapsets, mapset access | CPU: Unspecified
Platform: Unspecified |
g.mapsets GUI lists potential mapsets to access but there is no way to
check or uncheck them. I've tried clicking, double clicking, control/right
clicking. Nothing happens. The command works OK from the terminal but not
from the GUI. I just noticed this in 7.5. I don't know if it is a problem
in 7.4, but probably.
Is this Mac only or a larger issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
August 28, 2018, 2:23pm
2
Resolution: | Keywords: g.mapsets, mapset access
Comment (by veroandreo):
Tested in trunk in Fedora 28 and it works fine
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:1> ;
GDAL
August 28, 2018, 6:01pm
3
Comment (by cmbarton):
There are no checkboxes to check. This is probably a wxPython 3/4 issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:2> ;
GDAL
September 3, 2018, 7:31pm
4
Comment (by annakrat):
In [changeset:"73233" 73233]:
#!CommitTicketReference repository="" revision="73233"
wxGUI: missing checkboxes in g.mapsets dialog with wx4, see #3629
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:3> ;
GDAL
October 2, 2018, 6:29pm
5
Type: defect | Status: closed
Resolution: fixed | Keywords: g.mapsets, mapset access
Changes (by cmbarton):
* status: new => closed
* resolution: => fixed
Comment:
This is fixed in 7.4 on up. Closing
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:4> ;
GDAL
October 2, 2018, 6:52pm
6
Comment (by martinl):
Are you sure? related commit points only to trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:5> ;
GDAL
October 3, 2018, 1:29am
7
For the record, backported in r73480, r73481.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3629#comment:6> ;
