#3637: Use the system temporary directory for all GUI rendering files
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: assigned
Priority: minor | Milestone: 8.0.0
Component: wxGUI | Version: svn-trunk
Keywords: rendering PPM g.pnmcomp tempfile | CPU: Unspecified
NamedTemporaryFile |
Platform: Unspecified |
wxGUI uses standard Python `tempfile.NamedTemporaryFile` for rendering a
single layer (`GRASS_RENDER_FILE`):
mapfile = tempfile.NamedTemporaryFile(
suffix=tempfile_sfx, delete=False)
# we don't want it open, we just need the name
self.mapfile = mapfile.name
mapfile.close()
os.remove(self.mapfile) # remove empty file
self.maskfile = self.mapfile.rsplit(".", 1)[0] + ".pgm"
However, it uses GRASS GIS `grass.script.tempfile` for vector legend files
and `g.pnmcomp` output:
if self.type in ('vector', 'thememap'):
self._legrow = grass.tempfile(create=True)
# generated file for g.pnmcomp output for rendering the map
self.legfile = grass.tempfile(create=False) + '.leg'
self.tmpdir = os.path.dirname(self.legfile) # looks unused (?)
self.mapfile = grass.tempfile(create=False) + '.ppm'
source:grass/trunk/gui/wxpython/core/render.py
The render command (from WX_DEBUG, edited):
GUI D1/5: RenderLayerMgr.Render(d.rast
map=boundary_county_500m@PERMANENT):
force=1 img=/tmp/grass7-vpetras-23526/tmpNqGsdb.ppm
GUI D1/5: gcmd.RunCommand(): g.pnmcomp --o opacity=1.0 width=823
mask=/tmp/grass7-$USER-23526/tmpNqGsdb.pgm
height=502 bgcolor=255:255:255:255
input=/tmp/grass7-$USER-23526/tmpNqGsdb.ppm
output=/home/$USER/grassdata/nc_spm/a1/.tmp/$HOSTNAME/24140.0.ppm
`tempfile.NamedTemporaryFile` refers to `tempfile.TemporaryFile` which
refers to `tempfile.mkstemp` which says:
> The default directory is chosen from a platform-dependent list, but the
user of the application can control the directory location by setting the
`TMPDIR`, `TEMP` or `TMP` environment variables.
The order is not explicitly guaranteed in the documentation, but the
behavior on Linux with Python 2.7 is that `TMPDIR` is picked over `TMP`
which is the behavior we want. If that would change, but we wanted to
preserve the same behavior, there is a `dir` parameter which specified the
directory.
My intention is to use `tempfile.NamedTemporaryFile` for everything.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3637>
