[GRASS-dev] [GRASS GIS] #3638: v.distance linear matrix remove duplicate cat column & table associated without having map of distance lines
Reporter: Maellevd | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Vector | Version: 7.4.0
Keywords: v.distance | CPU: Unspecified
Platform: Linux |
Hello,
I would like to receive some details related to the v.distance module with
the graphical interface in GRASS 7.4.1.
1) When I try to generate a linear matrix of distances using v.distance, I
observe that the output contains a duplicate column (denoted “to_cat” and
"cat" in the example below).
Is there a reason for that ?
Is there a way to generate a linear matrix of distances without that
duplicated column ?
Here's an example command I ran:
v.distance -p -a from=hospitals@x to= hospitals@x upload=cat,dist
with the following output:
from_cat | to_cat | cat | dist
1 | 1 | 1 | 0
1 | 2 | 2 | 7489.1043632983983
1 | 3 | 3 | 339112.17046729225
2) When creating a table associated with the distance matrix:
a) why do my vector layers need to belong to the current mapsets while the
goal is not to update the vector layers ?
Example:
Command:
v.distance -a from=hospitals@PERMANENT to= hospitals@PERMANENT
output=map_connect_hospital_PERM upload=cat,dist column=to_cat,dist_min
table=tabl_dist_PERM
Output: ERROR: Bug: tentative de mise à jour d'une couche qui n'est pas
dans le jeu de cartes courant
b) why do you have to create a map of distance lines?
Indeed, it seems to me that it would be interesting to generate the table
without having this map.
Example:
Command:
v.distance -a from=hospitals@x to=hospitals@x output=map_connect_hospital
upload=cat,dist column=to_cat,dist_min table=tabl_dist
How to get rid of this "output = map_connect_hospital" option and just get
the table?
Thank you in advance for your feedback on these two concerns
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638&gt;
      Type: enhancement | Status: closed
Resolution: worksforme | Keywords: v.distance
       CPU: Unspecified | Platform: Linux
Changes (by sbl):
* status: new => closed
* resolution: => worksforme
Comment:
Please try the p-flag for generating only the table.
https://grass.osgeo.org/grass74/manuals/v.distance.html
As for the "duplicate" columns: Did you have a scroll down to from_cat 2?
From there cat and to cat should no longer be duplicates...
In principle, such questions are better asked at the user-mailing list
where you get more attention for the question. Closing this ticket as
worksforme, as I think what you want to achieve is already possible.
Please feel free to reopen if mailing list confirms lacking features or
unintended behavior…
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:1&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: v.distance
Changes (by sbl):
* status: closed => reopened
* resolution: worksforme =>
* type: enhancement => defect
Comment:
Sorry, I was a bit quick and see that
v.distance -p -a from=hospitals to= hospitals upload=cat,dist
indeed produce duplicate columns
Also,
ERROR: Bug: attempt to update map which is not in current mapset
should not happen.
In addition, the resulting map also lacks an attribute table (which it
should have). In more detail, the attribute table is produced, but not
connected to the vector map...
Writing table-formated output from GRASS directy to the database is a
different issue, and might be useful in more modules...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:2&gt;
Comment (by mlennert):
Thanks for reopening the ticket as there are several elements that are
real requests for enhancements or even bugs. However, I agree with sbl
that the original bug post could be less in the form of questions and more
in the form of a bug report / enhancement request. If you are not sure
about how to use a module than ask a question on the list. If you are
(pretty) sure that there is a problem with a module, post a ticket here
with the description of the problem.
The duplicate cat values come from the fact that when you use -a a to_cat
is automatically uploaded (otherwise how would one be able to use the
resulting matrix ?), so upload=cat is redundant. But if a linear output is
wanted, a second variable is needed. Try to run with upload=dist,to_x,to_y
and you will see that there is no duplication.
=== Bug ===
* The fact that the creation of a table is only possible when the input
maps are in the current mapset is a bug IMHO. It is due to the fact that
in the code updating the table and creating a new table is treated as
equal by calling Vect_set_db_updated(&From). Moving this to only the part
where the existing table is updated solves this issue.
See r73272 for the fix. I'll backport to the other branches ASAP.
=== Enhancements ===
* Currently, when using the -ap flag combination with one single upload
variable, the module automatically prints out a square matrix. However, in
certain situations it might be very useful to be able to print out a
linear matrix. This could handled by a flag, e.g. -s for square matrix,
instead of automatically
* I do not understand why an output map should be necessary to create an
output table. It can be useful to have such a table without a map.
* To add to this: when printing or creating a new table, one should be
able to determine column names, not only for updating an existing table
I'll attach a patch with these enhancement (plus some attempt at cleaning
up parser dependency instructions. This will partly change the module API,
though, so we'll have to decide how to apply.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:3&gt;
Comment (by sbl):
For a more general request of writing table-like results directly to
database see: #3639
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:4&gt;
Changes (by mlennert):
* Attachment "vdistance_matrix_table.diff" added.
patch for several issues identified in this ticket
Replying to [comment:3 mlennert]:
Done in r73273 and r73275.
cleaning up parser dependency instructions. This will partly change the
module API, though, so we'll have to decide how to apply.
Also done. This patch creates a new (-s) flag which allows to output a
square matrix if desired. By default the module will output a linear
matrix, whatever the number of upload variables.
The patch also allows creating a table without creating a map and allows
to determine column names in output, even when using -p or table=.
Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:5&gt;
  Priority: normal | Milestone: 7.8.3
See https://github.com/OSGeo/grass/pull/601
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:7&gt;
