[GRASS-dev] [GRASS GIS] #3639: Write table like output directly to database
Reporter: sbl | Owner: grass-dev@…
Priority: normal | Milestone: 8.0.0
Component: Database | Version: svn-trunk
Keywords: table,database,write | CPU: Unspecified
Platform: Unspecified |
It would be useful to be able to write table-like output from modules like
v.distance, r.stats, r.category, r.what, directly into a table in the
database...
(see also: #3638)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3639&gt;
Resolution: | Keywords: table,database,write
Comment (by mlennert):
In v.distance this is already available. I don't know if the solution is
sufficiently general, and the outputs generated by the modules
sufficiently similar to consider v.distance's code as boiler plate that
can be integrated elsewhere. One issue is column types that need to be
correctly defined. For the raster modules those will have to be determined
from the input raster maps.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3639#comment:1&gt;
Comment (by sbl):
I am considering adding a function to the Python scripting library for
parsing table-like stdout from GRASS modules into Numpy arrays. Nothing
complicated, but probably a convenient wrapper function!?
See:
def stdout2numpy(stdout=None, sep=',', names=False, null_value=None,
                  fill_value=None, comments='#', usecols=None):
     """Read table-like output from grass modules as Numpy array;
     format instructions are handed down to Numpys genfromtxt function
     param str|byte stdout: tabular stdout from GRASS GIS module call
     param str sep: Separator delimiting columns
     param list names: List of strings with names for columns
     param str null_value: Characters representing the no-data value
     param str fill_value: Value to fill no-data with
     param str comments: Character that
     param list usecols: List of columns to import
     import numpy as np
     from io import BytesIO
     if type(stdout) == str:
         stdout = gscript.encode(stdout)
     elif type(stdout) != byte:
         gscript.fatal(_('Unsupported data type'))
     np_array = np.genfromtxt(BytesIO(stdout),
                              missing_values=null_value,
                              filling_values=fill_value,
                              usecols=usecols,
                              names=names,
                              dtype=None, delimiter=sep)
     return np_array
or alternatively as np_parse_command (equivalent to parse_command()):
def np_parse_command(*args, **kwargs):
     """Passes all arguments to read_command, then parses the output
     using Numpys genfromtxt() function to generate a Numpy array from
     table like output.
     Parsing options in Numpys genfromtxt() function can be
     optionally given by <em>parse</em> dictionary, e.g.
         parse_command(..., parse = { 'delimiter' : '|' }))
     As far as possible, at least standard parser options in GRASS
     commands are handed down and translated to genfromtxt()
     automatically, e.g. separator (GRASS) -> delimiter (Numpy).
     import numpy as np
     stdout = read_command(*args, **kwargs)
     filling_values = parse['filling_values'] if 'filling_values' in parse
else np.nan
     usecols = parse['usecols'] if 'usecols' in parse else None
     names = parse['names'] if 'names' in parse else None
     dtype = parse['dtype'] if 'dtype' in parse else None
     # Check if separator is specified in GRASS command
     if 'delimiter' not in parse:
         if 'separator' in args:
             parse['delimiter'] = args['separator']
         elif 'separator' in kwargs:
             parse['delimiter'] = kwargs['separator']
         else:
             parse['delimiter'] = ','
     # Check if null_value is specified in GRASS command
     if 'missing_values' not in parse:
         if 'null_value' in args:
             parse['missing_values'] = args['null_value']
         elif 'null_value' in kwargs:
             parse['missing_values'] = kwargs['null_value']
         else:
             parse['missing_values'] = '*'
     np_array = np.genfromtxt(BytesIO(stdout), **parse)
     return np_array
That would probably be a first step for a Python function that can write
output to DB...
Any thoughts/opinions?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3639#comment:2&gt;
