#3642: r.pi addon compilation issue on Windows
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Addons | Version: unspecified
Keywords: r.pi | CPU: Unspecified
Platform: MSWindows 8 |
The r.pi.* comes with r.pi.library which provides
and the other modules depending on that. However, at compile time the
library is produced but then not found:
mkdir -p /c/Users/landa/grass_packager/grass741/x86/addons/r.pi/bin
mkdir -p /c/Users/landa/grass_packager/grass741/x86/addons/r.pi/etc
mkdir -p /c/Users/landa/grass_packager/grass741/x86/addons/r.pi/docs/html
mkdir -p
/c/Users/landa/grass_packager/grass741/x86/addons/r.pi/docs/man/man1
mkdir -p
/c/Users/landa/grass_packager/grass741/x86/addons/r.pi/docs/man/man1/man1
make -C r.pi.library || echo
/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.library >>
/c/msys32/usr/src/grass741/error.log
make[1]: Entering directory
'/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.library'
test -d OBJ.i386-w64-mingw32 || mkdir -p OBJ.i386-w64-mingw32
gcc -I/c/OSGeo4W32/include -g -O2 -I/c/OSGeo4W32/include
-I/c/msys32/usr/src/grass741/dist.i386-w64-mingw32/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
-DRELDIR=\"/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.library\"
-o OBJ.i386-w64-mingw32/draw.o -c draw.c
-o OBJ.i386-w64-mingw32/frag.o -c frag.c
-o OBJ.i386-w64-mingw32/helpers.o -c helpers.c
-o OBJ.i386-w64-mingw32/stat_method.o -c stat_method.c
gcc -shared -o
/c/msys32/usr/src/grass741/dist.i386-w64-mingw32/lib/libgrass_rpi.7.4.1.dll
-L/c/msys32/usr/src/grass741/dist.i386-w64-mingw32/lib
-L/c/msys32/usr/src/grass741/mswindows/osgeo4w/lib -lz -Wl,--export-
dynamic,--enable-runtime-pseudo-reloc
OBJ.i386-w64-mingw32/draw.o OBJ.i386-w64-mingw32/frag.o
OBJ.i386-w64-mingw32/helpers.o OBJ.i386-w64-mingw32/stat_method.o
-lgrass_gis.7.4.1 -lintl
C:/msys32/mingw32/bin/../lib/gcc/i686-w64-mingw32/5.2.0/../../../../i686-w64-mingw32/bin/ld.exe:
warning: --export-dynamic is not supported for PE targets, did you mean
--export-all-symbols?
if [ "" != "" -a -f "".html ] ; then make html ; fi
make[1]: Leaving directory
The library was apparently generated as
but:
make -C r.pi.corearea || echo
/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.corearea >>
'/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.corearea'
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-DRELDIR=\"/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.corearea\"
-o OBJ.i386-w64-mingw32/func.o -c func.c
-o OBJ.i386-w64-mingw32/main.o -c main.c
make OBJ.i386-w64-mingw32/r.pi.corearea.manifest.res && gcc
-L/c/msys32/usr/src/grass741/mswindows/osgeo4w/lib -o
/c/Users/landa/grass_packager/grass741/x86/addons/r.pi/bin/r.pi.corearea.exe
OBJ.i386-w64-mingw32/func.o OBJ.i386-w64-mingw32/main.o
/c/msys32/usr/src/grass741/dist.i386-w64-mingw32/lib/fmode.o
OBJ.i386-w64-mingw32/r.pi.corearea.manifest.res -lgrass_stats.7.4.1
-lgrass_raster.7.4.1 -lgrass_gis.7.4.1 -lintl -lgrass_rpi
make[2]: Entering directory
make[2]: Circular /c/msys32/usr/src/grass741/mswindows/generic.manifest.rc
<- /c/msys32/usr/src/grass741/mswindows/generic.manifest.rc dependency
dropped.
sed -e 's/@CMD@/r.pi.corearea/' \
-e 's/@VER_MAJOR@/7/' \
-e 's/@VER_MINOR@/4/' \
-e 's/@VER_RELEASE@/1/' \
/c/msys32/usr/src/grass741/mswindows/generic.manifest.rc >
OBJ.i386-w64-mingw32/r.pi.corearea.manifest.rc
sed 's/@CMD@/r.pi.corearea/'
/c/msys32/usr/src/grass741/mswindows/generic.manifest >
OBJ.i386-w64-mingw32/r.pi.corearea.exe.manifest
windres --input=OBJ.i386-w64-mingw32/r.pi.corearea.manifest.rc --input-
format=rc --output=OBJ.i386-w64-mingw32/r.pi.corearea.manifest.res
--output-format=coff -I/c/msys32/usr/src/grass741/mswindows
rm OBJ.i386-w64-mingw32/r.pi.corearea.manifest.rc
make[2]: Leaving directory
cannot find -lgrass_rpi
collect2.exe: error: ld returned 1 exit status
/c/msys32/usr/src/grass741/include/Make/Module.make:18: recipe for target
'/c/Users/landa/grass_packager/grass741/x86/addons/r.pi/bin/r.pi.corearea.exe'
failed
make[1]: ***
[/c/Users/landa/grass_packager/grass741/x86/addons/r.pi/bin/r.pi.corearea.exe]
Error 1
make -C r.pi.corr.mw || echo
/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.corr.mw >>
'/c/msys32/usr/src/grass_addons/grass7/raster/r.pi/r.pi.corr.mw'
Any ideas?
Log: http://wingrass.fsv.cvut.cz/grass74/x86/addons/latest/logs/r.pi.log
Ticket URL: <https://trac.osgeo.org/grass/ticket/3642>
