GDAL
September 19, 2018, 1:45am
1
#3649: Cartographic composer: OK, pointer and pan buttons do not work
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.psmap | CPU: Unspecified
Platform: Linux |
The buttons "Pointer" and "Pan" in the Cartographic composer do not work
properly, neither does the OK button when adding maps or decorations.
The "pointer" does not allow to select and move map elements as it used to
do (it does nothing basically) and the "pan" zooms instead of panning.
Furthermore, every time I add a map layer or decoration, the button OK
does not close the dialog box. Instead, I have to close with the "x" in
the corner.
This prevents from using G7:g.gui.psmap to produce any reasonable output
map.
System Info:
GRASS version: 7.7.svn
GRASS SVN revision: r73362
Build date: 2018-09-18
Build platform: x86_64-pc-linux-gnu
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.6.1
SQLite: 3.22.0
Python: 2.7.15
wxPython: 3.0.2.0
Platform: Linux-4.18.7-200.fc28.x86_64-x86_64-with-fedora-28-Twenty_Eight
Is there any further testing I can do?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
September 19, 2018, 3:03am
2
Type: defect | Status: closed
Resolution: fixed | Keywords: g.gui.psmap
CPU: Unspecified | Platform: Linux
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"73364" 73364]:
#!CommitTicketReference repository="" revision="73364"
wxGUI: fix #3649
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649#comment:1> ;
GDAL
September 19, 2018, 5:21am
3
Comment (by martinl):
Milestone set to 7.6, missing backport?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649#comment:2> ;
GDAL
4
Type: defect | Status: reopened
Resolution: | Keywords: g.gui.psmap
Changes (by martinl):
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649#comment:3> ;
GDAL
September 19, 2018, 11:51am
5
Comment (by veroandreo):
Replying to [comment:1 annakrat]:
> wxGUI: fix #3649
Thanks, this fixed the reported issues.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649#comment:4> ;
GDAL
September 19, 2018, 1:18pm
6
Priority: normal | Milestone: 7.8.0
* status: reopened => closed
* milestone: 7.6.0 => 7.8.0
Comment:
Replying to [comment:2 martinl]:
No, it was just in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649#comment:5> ;
