[GRASS-dev] [GRASS GIS] #365: wxGUI: ** (python:3840): WARNING **: IPP request failed with status 1280
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
For some days now GRASS 6.4 SVN has been printing a following warning o
the terminal, once a second or so:
This makes using CLI troublesome.
Once I close wxGUI the wrning is gone.
Debian testing amd64.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365&gt;
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [ticket:365 msieczka]:
Googling for "IPP request failed" indicates that this is generated by
libgnomeprint polling CUPS when no printer is available.
It might be possible to ensure that this doesn't occur if you don't use
any features related to printing. Unfortunately, once you do, there isn't
much that we can do about it. glib provides a mechanism to override the
default logging handler, but neither wxWidgets nor wxPython appear to use
this or expose it to applications.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:1&gt;
  Platform: Linux | Cpu: All
Changes (by msieczka):
  * cpu: x86-64 => All
Comment:
Replying to [comment:1 glynn]:
In my case the culprit seems to be that CUPS was disabled (as I don't
usually use any printers anyway). Once I turned CUPS service on, in spite
of no printers configured, the warning is gone.
> to printing. Unfortunately, once you do, there isn't much that we can do
about it. glib
> provides a mechanism to override the default logging handler, but
> wxPython appear to use this or expose it to applications.
So basically when CUPS is disabled/not installed on a machine, GRASS
terminal will always be borked like this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 msieczka]:
Modifying !PrintOptions to create the wx.!PrintData object on first use
may mean that the problems won't arise unless you select any of the items
from the print menu on the map display, histogram or profile windows
(presumably, you're not likely to select those items if your system isn't
set up for printing).
You can test whether this is the case by commenting out the lines:
         self.printData = wx.PrintData()
         self.printData.SetPaperId(wx.PAPER_LETTER)
         self.printData.SetPrintMode(wx.PRINT_MODE_PRINTER)
in !PrintOptions.!__init!__ in
$GISBASE/etc/wxpython/gui_modules/disp_print.py.
I can't test it, as my version of wxWidgets is built without Gnome
support, so I don't get these warnings.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:3&gt;
Comment (by msieczka):
Replying to [comment:3 glynn]:
Doing the above prevents WARNINGs, but also completely disables all
printing functionality. Choosing any tool under "Print display" has no
effect.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:4&gt;
Comment (by glynn):
Replying to [comment:4 msieczka]:
effect.
That's to be expected; it wasn't intended as a fix, just a way to confirm
the source of the warnings.
I'll commit a proper fix. However, once you choose any of the print
related menu options, there doesn't appear to be much that we can do about
any warnings that libgnomeprint decides to generate.
In particular, the wx.PrintData() object has to be persistent so that any
settings made via the "Page Setup" are used for printing. Hmm; I suppose
that we could add a "Reset" option to remove any references to the
wx.PrintData() object, although that won't help if wx keeps its print-
handling thread running anyhow.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:5&gt;
Comment (by glynn):
Can you try the attached patch?
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:6&gt;
Replying to [comment:6 glynn]:
It helps. No warnings until I select a tool from "Print display". Once I
do however, the warnings start cropping in 5 seconds intervals.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:7&gt;
Comment (by glynn):
Replying to [comment:7 msieczka]:
Do they stop if you select the "Reset" option?
In any case, that's all that we can do. Committed as r34380 (7.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:8&gt;
Replying to [comment:8 glynn]:
Nope.
Much better anyway. Thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:9&gt;
Comment (by glynn):
Replying to [comment:9 msieczka]:
> Nope.
In that case, I'll remove the Reset option, as it serves no purpose.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:10&gt;
Comment (by cmbarton):
I think we should change this to fixed (as much as possible) or wontfix,
because it seems that nothing else can be done. It only arises if CUPS is
disabled with Gnome printing it seems. It should also be merged with the
couple of other reports about CUPS and Gnome printing, as they all seem
related.
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:11&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
Changes (by cmbarton):
  * status: new => closed
  * resolution: => wontfix
Comment:
No one has responded since last December. Changing to wontfix because
there is nothing we can do in the wxPython GUI to improve this further.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/365#comment:12&gt;
