[GRASS-dev] [GRASS GIS] #3650: Cartographic composer: scale and rotation options do not work for north arrow
arrow
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
When I try to add a North Arrow in the Cartographic composer, if I accept
all settings by default and click OK, it works, but I get a huge north
arrow.
If I then try to scale or rotate the north arrow, the apply button does
not produce any visible effect and the OK button does not close the
dialog, only the "x" in the corner does, and afterwards the grey box
representing the north arrow disappears. Then, the arrow appears in the
preview, but I do not have control over it.
I attach screenshots.
System
GRASS version: 7.7.svn
GRASS SVN revision: r73364
Build date: 2018-09-19
Build platform: x86_64-pc-linux-gnu
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.6.1
SQLite: 3.22.0
Python: 2.7.15
wxPython: 3.0.2.0
Platform: Linux-4.18.7-200.fc28.x86_64-x86_64-with-fedora-28-Twenty_Eight
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650&gt;
arrow
Resolution: | Keywords:
Changes (by veroandreo):
* Attachment "g.gui.psmap_draft.png" added.
draft mode in g.gui.psmap, after north arrow has disappeared
arrow
* Attachment "g.gui.psmap_preview.png" added.
preview mode in g.gui.psmap, north arrow appears (not shrunk as expected)
arrow
Comment (by annakrat):
I can't reproduce. Maybe could you list your steps exactly how you do it?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:1&gt;
arrow
Also does it work in 76?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:2&gt;
arrow
Comment (by veroandreo):
Replying to [comment:1 annakrat]:
it?
1. Open Cartographic composer from GUI (File--> Cartographic composer)
2. Add map frame and select elevation raster map
3. Add north arrow, select n_arrow1_fancy.eps, click OK
4. Double click over north arrow in map
5. 2 or 3 clicks over minus in Scale, Click Apply <<-- nothing
6. Click OK <<-- nothing
7. Close "North Arrow Setting" box with the x in the corner
8. North arrow becomes invisible
9. Generate preview and north arrow is there (original position and size)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:3&gt;
arrow
Replying to [comment:3 veroandreo]:
it?
size)
I still can't reproduce. Isn't there any error in Layer manager console?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:4&gt;
arrow
Yes, here it is:
   File "/home/veroandreo/software/grass7_trunk/dist.x86_64
-pc-linux-gnu/gui/wxpython/psmap/dialogs.py", line 440, in
OnApply
self.parent.DialogDataChanged(id=self.id)
-pc-linux-gnu/gui/wxpython/psmap/frame.py", line 1012, in
DialogDataChanged
bb=drawRectangle)
-pc-linux-gnu/gui/wxpython/psmap/frame.py", line 2180, in
Draw
bbox=bb)
-pc-linux-gnu/gui/wxpython/psmap/frame.py", line 2288, in
DrawBitmap
bbox[3])), resample=PILImage.BICUBIC)
   File "/usr/lib64/python2.7/site-packages/PIL/Image.py",
line 1749, in resize
return self._new(self.im.resize(size, resample, box))
ValueError
height and width must be > 0
I think it is because I click over minus more than 3 or 4 times and then
north arrow becomes very small... The problem is I only see minus or plus
sign, I do not know how much I reduce the size or rotate (see attachment,
is this the same for others or only in fedora?).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:5&gt;
arrow
* Attachment "cartographic_comp_north_arrow_dialog.png" added.
dialog box for north arrow in cartographic composer, note scale and
rotation area, only + and - are visible
arrow
  Priority: normal | Milestone: 7.8.0
Component: Ps.map | Version: svn-trunk
* version: unspecified => svn-trunk
* component: Default => Ps.map
* milestone: => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:6&gt;
