[GRASS-dev] [GRASS GIS] #3657: "Command prompt - Log files" produces empty log files
Reporter: frafra | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: x86-64
Platform: Linux |
I tried to switch it on and off, save/Select the file multiple time, but
it always create a 0 bytes text file, no matter which command I Select
from the menu.
GRASS 7.4.1 on OSGeo Live 11.0 running on VirtualBox.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3657&gt;
  Reporter: frafra | Owner: martinl
      Type: defect | Status: assigned
  Priority: normal | Milestone: 7.4.2
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
* component: Default => wxGUI
* milestone: => 7.4.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3657#comment:1&gt;
Comment (by martinl):
In [changeset:"73417" 73417]:
#!CommitTicketReference repository="" revision="73417"
Command prompt - Log files produces empty log files, see #3657
Ticket URL: <https://trac.osgeo.org/grass/ticket/3657#comment:2&gt;
In [changeset:"73420" 73420]:
#!CommitTicketReference repository="" revision="73420"
Command prompt - Log files produces empty log files, see #3657 (g76: merge
r73417 from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3657#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"73421" 73421]:
#!CommitTicketReference repository="" revision="73421"
Command prompt - Log files produces empty log files, closes #3657 (g76:
merge r73417 from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3657#comment:4&gt;
