#3659: i.modis.import fails if 'datum' not defined
Reporter: Nikos Alexandris | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: unspecified
Keywords: i.modis, i.modis.import | CPU: Unspecified
Platform: Unspecified |
`i.modis.import` will fail if the 'datum' is not defined. For example, in
a LOCATION as the following:
g.proj -p
-PROJ_INFO-------------------------------------------------
ellps : clark66
proj : ll
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
the following command will fail
i.modis.import input=MOD11A1.A2016174.h18v04.006.2016240225941.hdf
and will report
File "/home/user/.grass7/addons/scripts/i.modis.import", line 607, in
<module>
sys.exit(main())
File "/home/user/.grass7/addons/scripts/i.modis.import", line 559, in main
single(options, remove, analyze, over, outfile)
File "/home/user/.grass7/addons/scripts/i.modis.import", line 360, in
single
projObj = projection()
File "/home/user/.grass7/addons/etc/i.modis/rmodislib.py", line 353, in
__init__
if self.proj['datum']:
KeyError: 'datum'
Should the error message be improved, i.e. provide a clue to "switch" to
another location?
