#3664: d.text: background color cannot be disabled
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: d.text, background | CPU: Unspecified
Platform: Unspecified |
Currently, if one tries to add text to a map either calling G7:d.text from
command line with `d.text --ui` or from the toolbar of the Map Display,
there's no option to disable the background as in G7:d.legend for example.
Meanwhile, d.text applied over a wx-monitor draws text without background
by default.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3664>
