[GRASS-dev] [GRASS GIS] #367: g.region segmentation violation when creating EPSG:4326 location
Reporter: epatton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: g.region, segmentation fault | Platform: Linux
      Cpu: x86-64 |
I'm having problems creating a new EPSG:4326 location (latlong, WGS84).
This is from a fresh 'make distclean' of Grass 6.4.
When trying to create a Lat-Long WGS84 location, gis.m aborts as the GIS
Manager and Map DIsplay windows are being created, with the following
error:
Error in startup script: can't read "monitor_zooms(1,1,n)": no such
variable
     while executing
"lappend region $monitor_zooms($mon,1,$attr)"
     (procedure "MapCanvas::currentzoom" line 15)
     invoked from within
"MapCanvas::currentzoom $mon"
     (procedure "MapCanvas::coordconv" line 23)
     invoked from within
"MapCanvas::coordconv $mon"
     (procedure "MapCanvas::create" line 68)
     invoked from within
"MapCanvas::create"
     (procedure "Gm::startmon" line 11)
     invoked from within
"Gm::startmon"
     (procedure "Gm::create" line 79)
     invoked from within
"Gm::create"
     (procedure "main" line 30)
     invoked from within
"main $argc $argv"
     (file "/usr/local/grass-6.4.svn/etc/gm/gm.tcl" line 566)
Here's g.proj output:
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
I am able to enter this newly-created Grass location in text mode. Running
"g.region -p" from the command line gives "segmentation fault".
I only have these errors when trying to create or use a Lat-Long, WGS84
location. My UTM locations seem to be fine.
I've checked that my epsg file is in the correct location where Grass
expects it to be (/usr/share/proj/epsg).
Any ideas?
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367&gt;
Resolution: | Keywords: g.region, segmentation fault
  Platform: Linux | Cpu: x86-64
Comment (by marisn):
Running "g.region -p" from the command line gives "segmentation fault"
is the real root of problem.
Let me guess - Ubuntu? Install newer GDAL version and then svn up && make
distclean && make
Otherwise - gdb g.region; run; bt.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367#comment:1&gt;
Comment (by epatton):
Thanks. I've removed the Ubuntu versions of geos, proj and gdal, and
compiled each of those from source. No errors during configure or make for
any of them.
Grass configure proceeds fine, and I can confirm that proj and gdal are
installed. I get a ton of make errors, with about 30 modules failing. The
first in the error.log is /usr/local/grass6_devel/lib/proj; here's the
error I get when I change to this directory and run make clean and then
'make':
/usr/bin/ld: /usr/local/lib/libgdal.a(cpl_conv.o): relocation R_X86_64_32S
against `std::basic_string<char, std::char_traits<char>,
std::allocator<char> >::_Rep::_S_empty_rep_storage' can not be used when
making a shared object; recompile with -fPIC
/usr/local/lib/libgdal.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/usr/local/grass6_devel/dist.x86_64-unknown-linux-
gnu/lib/libgrass_gproj.6.4.svn.so] Error 1
Here is the Grass configure statement:
CFLAGS="-g -Wall -fPIC"
./configure \
--enable-64bit \
--with-libs=/usr/lib64 \
--with-tcltk-includes=/usr/include/tcl8.5 \
--without-postgres \
--with-sqlite \
--with-sqlite-includes=/usr/include \
--with-freetype \
--with-freetype-includes=/usr/include/freetype2 \
--with-readline \
--with-cxx \
--with-gdal \
--with-gdal-includes=/usr/local/include \
--enable-largefile \
--with-proj \
--with-proj-share=/usr/local/share/proj \
--with-proj-lib=/usr/local/lib \
--with-fftw \
--with-fftw-includes=/usr/include \
--with-fftw-libs=/usr/lib \
--with-python \
--with-opengl \
--with-opengl-includes=/usr/include/GL \
--with-python=yes \
--with-python-includes=/usr/bin/ \
--with-wxwidgets=yes \
--with-cairo \
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.region, segmentation fault
Changes (by epatton):
  * status: new => closed
  * resolution: => fixed
Comment:
Solved. I was using a too-new version of gdal, 1.6.0 beta2. I removed this
version, and installed 1.5.3 instead. No more errors!
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/367#comment:3&gt;
