[GRASS-dev] [GRASS GIS] #3672: r.in.gdal -a and the imported map's east boundary
Reporter: Nikos Alexandris | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: unspecified
Keywords: r.in.gdal | CPU: Unspecified
Platform: Unspecified |
I downloaded the hourly 5km LST product
"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc" from Copernicus (see also
the product's user manual:
https://land.copernicus.eu/global/sites/cgls.vito.be/files/products/GIOGL1_PUM_LST-I1.40.pdf)
The reported pixel size and boundary coordinates for the "LST" layer, are:
gdalinfo NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST |grep
Pixel
Pixel Size = (0.044642858207226,-0.044642858207226)
and
Coordinates -A5
Corner Coordinates:
Upper Left (-180.0223214, 80.0223214) (180d 1'20.36"W, 80d 1'20.36"N)
Lower Left (-180.0223214, -79.9776824) (180d 1'20.36"W, 79d58'39.66"S)
Upper Right ( 179.9776872, 80.0223214) (179d58'39.67"E, 80d 1'20.36"N)
Lower Right ( 179.9776872, -79.9776824) (179d58'39.67"E, 79d58'39.66"S)
Center ( -0.0223171, 0.0223195) ( 0d 1'20.34"W, 0d 1'20.35"N)
Importing the "LST" layer without any region-related flag, preserves the
original spatial resolution. The command
r.in.gdal in=NETCDF:"g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc":LST
output=g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST -o
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Over-riding projection check
360 degree EW extent is exceeded by 0.000192261 cells
Importing raster map <g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST>...
100%
results in
r.info g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST -g
360 degree EW extent is exceeded by 0.00019226 cells
north=80.0223214291667
south=-79.9776823855556
east=179.977687153889
west=-180.022321429167
nsres=0.0446428582072328
ewres=0.0446428582072241
rows=3584
cols=8064
cells=28901376
datatype=CELL
ncats=0
The west & east boundaries `-180.022321429167` & `179.977687153889` are
close to the metadata-reported ones `-180.0223214` &
`179.9776872`.
However, importing with the `-a` flag,
r.in.gdal in=NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST
out=import_with_a -o --o -a
results in
r.info import_with_a -g
north=80.0223333333333
south=-79.9634444444444
east=179.945666666667
west=-180.022333333333
nsres=0.0446388888888889
ewres=0.0446388888888889
rows=3584
cols=8064
cells=28901376
datatype=CELL
ncats=0
the east boundary `179.945666666667` is "far" from what it should
expectedly be: `179.977687153889 - 179.945666666667` = `0.03202049`.
See also: https://lists.osgeo.org/pipermail/grass-
user/2018-October/079239.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3672&gt;
