[GRASS-dev] [GRASS GIS] #3673: wxGUI: UnicodeEncodeError when querying vector map
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: wxGUI | Version: svn-trunk
Keywords: wxGUI query encoding | CPU: Unspecified
Platform: Unspecified |
Querying a vector map, I get the following error:
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1379, in
MouseActions
self.OnLeftUp(event)
   File
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1560, in
OnLeftUp
y=self.mouse['end'][1])
   File
linux-gnu/etc/python/grass/pydispatch/signal.py", line 229,
in emit
dispatcher.send(signal=self, *args, **kwargs)
   File
linux-gnu/etc/python/grass/pydispatch/dispatcher.py", line
349, in send
**named
   File
linux-gnu/etc/python/grass/pydispatch/robustapply.py", line
60, in robustApply
return receiver(*arguments, **named)
   File
linux-gnu/gui/wxpython/mapdisp/frame.py", line 912, in Query
self.QueryMap(east, north, qdist, rast, vect)
   File
linux-gnu/gui/wxpython/mapdisp/frame.py", line 976, in
QueryMap
self.dialogs['query'] = QueryDialog(parent=self,
data=result)
   File
linux-gnu/gui/wxpython/gui_core/query.py", line 52, in
__init__
self._model = QueryTreeBuilder(self.data,
column=self._colNames[1])
   File
linux-gnu/gui/wxpython/gui_core/query.py", line 238, in
QueryTreeBuilder
addNode(parent=model.root, data=part, model=model)
   File
linux-gnu/gui/wxpython/gui_core/query.py", line 227, in
addNode
addNode(parent=node, data=v, model=model)
   File
addNode
   File
linux-gnu/gui/wxpython/gui_core/query.py", line 230, in
addNode
v = str(v)
UnicodeEncodeError
'ascii' codec can't encode character u'\xe8' in position 25:
ordinal not in range(128)
g.version -g
version=7.7.svn
date=2018
revision=r73472M
build_date=2018-10-01
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3673&gt;
Resolution: | Keywords: wxGUI query encoding
Comment (by annakrat):
In [changeset:"73493" 73493]:
#!CommitTicketReference repository="" revision="73493"
wxGUI: fix querying for Python 2/3, see #3673
Ticket URL: <https://trac.osgeo.org/grass/ticket/3673#comment:1&gt;
Please test, no backporting needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3673#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxGUI query encoding
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:1 annakrat]:
Seems to be fixed. Thanks, Anna !
Ticket URL: <https://trac.osgeo.org/grass/ticket/3673#comment:3&gt;
