#3675: g.gui.rlisetup: cannot create the configuration file
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.rlisetup | CPU: Unspecified
Platform: Unspecified |
When hitting the "Create" button in the G7:g.gui.rlisetup dialog, I get
the following error in the GUI console:
File "/home/veroandreo/software/grass7_trunk/dist.x86_64
-pc-linux-gnu/gui/wxpython/rlisetup/frame.py", line 241, in
OnNew
RLIWizard(self)
-pc-linux-gnu/gui/wxpython/rlisetup/wizard.py", line 68, in
__init__
self.samplingareapage = SamplingAreasPage(self.wizard, self)
-pc-linux-gnu/gui/wxpython/rlisetup/wizard.py", line 940, in
__init__
self.areaOK.SetToolTip(wx.ToolTip(_("Select if use area by
area")))
-pc-linux-gnu/gui/wxpython/gui_core/wrap.py", line 103, in
SetToolTip
wx.Button.SetToolTipString(self, tip)
File "/usr/lib64/python2.7/site-
packages/wx-3.0-gtk3/wx/_core.py", line 11382, in
SetToolTipString
return _core_.Window_SetToolTipString(*args, **kwargs)
TypeError
String or Unicode type required
G7:g.gui.rlisetup works fine in grass74 relbranch, so I created it there
(but I Sohad further errors in r.li.* modules, see #3676). So, the config
file issue seems to be a problem in trunk only. Maybe also 76, this latter
I have not tried, though.
