[GRASS-dev] [GRASS GIS] #3685: pygrass GridModule: ERROR: Unable to open element file <windows>
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: PyGRASS | Version: svn-trunk
Keywords: GridModule | CPU: Unspecified
Platform: Unspecified |
I've been using a script with code resembling the attached python script
for months (notably through the i.cutlines addon), without any error. It
uses the GridModule class from pygrass to run i.zc on tiles of an input
map (as i.zc reads everything into memory).
I suddenly get the following errors, both with trunk and release76:
GRASS 7.7.svn (nc_spm_08):~ > ./grid_test.py
Creating edge map
ERROR: ERROR: ERROR: UnableUnableUnable toto openopen elementelement
filefile to open<windows> <windows>for elementfor file
        <tmp.grid_test.py.498@izc_000_002>
  <tmp.grid_test.py.498@izc_000_003>
<windows> for
        <tmp.grid_test.py.498@izc_000_001>
ERROR: Unable to open element file <windows> for
        <tmp.grid_test.py.498@izc_000_000>
ERROR: ERROR: Unable to open element file <windows> for
        <tmp.grid_test.py.498@izc_001_001>
        <tmp.grid_test.py.498@izc_001_002>
        <tmp.grid_test.py.498@izc_001_000>
        <tmp.grid_test.py.498@izc_001_003>
        <tmp.grid_test.py.498@izc_002_000>
        <tmp.grid_test.py.498@izc_002_001>
        <tmp.grid_test.py.498@izc_002_003>
        <tmp.grid_test.py.498@izc_002_002>
ERROR: ERROR: UnableUnable toto openopen elementelement filefile
<windows><windows> forfor
<tmp.grid_test.py.498@izc_002_002><tmp.grid_test.py.498@izc_002_003>
        <tmp.grid_test.py.498@izc_003_001>
        <tmp.grid_test.py.498@izc_003_000>
        ERROR: <tmp.grid_test.py.498@izc_003_002>
        <tmp.grid_test.py.498@izc_003_003>
   File "./grid_test.py", line 33, in <module>
     grd.run()
   File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 568, in run
     self.patch()
gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 609, in patch
     self.start_row, self.start_col, self.out_prefix)
gnu/etc/python/grass/pygrass/modules/grid/patch.py", line 79, in
rpatch_map
     rtype.open('r')
gnu/etc/python/grass/pygrass/raster/__init__.py", line 210, in open
     raise OpenError(str_err)
grass.exceptions.OpenError: The map does not exist, I can't open in 'r'
mode
Does anyone have any idea what might be going wrong ? When I look into one
of these izc_* directories, I see the following:
GRASS 7.6.svn (nc_spm_08):~ > ls -l GRASSDATA/nc_spm_08/izc_002_002/
total 16
-rw-r--r-- 1 mlennert mlennert 14 oct 19 11:20 CURGROUP
-rw-r--r-- 1 mlennert mlennert 291 oct 19 11:20 SEARCH_PATH
-rw-r--r-- 1 mlennert mlennert 81 oct 19 11:20 VAR
-rw-r--r-- 1 mlennert mlennert 317 oct 19 11:20 WIND
Does anyone have any idea about what might be going on ? This keeps me
from launching quite long-running processes, so it would be great if I
could solve this rapidly. I have to admit I'm a bit lost even just trying
to understand what might be wrong and how I should debug this. Any hints
are more than welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3685&gt;
Hi everyone,
As this is quite urgent in the context of my work, I would love some help on this issue. Does anyone have any hint as to where I should start looking about this ?
Moritz
-------- Forwarded Message --------
Subject: [GRASS-dev] [GRASS GIS] #3685: pygrass GridModule: ERROR: Unable to open element file <windows>
Date: Fri, 19 Oct 2018 09:23:26 -0000
Reply-To: grass-dev@lists.osgeo.org
CC: grass-dev@lists.osgeo.org
  Creating edge map
  <windows> for
      grd.run()
      self.patch()
  rpatch_map
      rtype.open('r')
  mode
  total 16
Resolution: | Keywords: GridModule
Changes (by mlennert):
* Attachment "grid_test.py" added.
script to reproduce error
Comment (by Nikos Alexandris):
Same errors here. What is the content of the WIND file(s).
Here, all of the WIND files, inside each izc_* directory, are identical
and set to
proj: 99
zone: 0
north: 1000
south: 0
east: 1000
west: 0
cols: 1000
rows: 1000
e-w resol: 1
n-s resol: 1
top: 1.000000000000000
bottom: 0.000000000000000
cols3: 1000
rows3: 1000
depths: 1
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
which is the "default" region in the Location 'nc_spm_08_grass7', Mapset
'PERMANENT':
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 1000
south: 0
west: 0
east: 1000
nsres: 1
ewres: 1
rows: 1000
cols: 1000
cells: 1000000
Yet the raster map lies elsewhere:
r.info ortho_2001_t792_1m -g
north=222504
south=219456
east=640081
west=637033
nsres=1
ewres=1
rows=3048
cols=3048
cells=9290304
datatype=CELL
ncats=188
Or is it irrelevant, and they are just set back to the default after the
script's completion, since the script uses `gscript.use_temp_region()`?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3685#comment:1&gt;
Comment (by mmetz):
Replying to [ticket:3685 mlennert]:
> Creating edge map
> <windows> for
> grd.run()
> self.patch()
rpatch_map
> rtype.open('r')
mode
one of these izc_* directories, I see the following:
> total 16
I think this is related to `gscript.use_temp_region()`. The error messages
are all related to a region named `tmp.grid_test.py.498`, but this region
does not exist in the subsequently created temporary mapset. This
temporary region is defined in the current mapset and only valid in the
current mapset. Other temporary mapsets created later on in the script can
not access this temporary region definition, thus the ERRORs searching for
`tmp.grid_test.py.498` in different mapsets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3685#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: GridModule
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 mmetz]:
messages are all related to a region named `tmp.grid_test.py.498`, but
this region does not exist in the subsequently created temporary mapset.
This temporary region is defined in the current mapset and only valid in
the current mapset. Other temporary mapsets created later on in the script
can not access this temporary region definition, thus the ERRORs searching
for `tmp.grid_test.py.498` in different mapsets.
Yes, that's it. Thanks to both of you and sorry for the noise. I'm busy
with too many things in parallel and forgot that I had only added
use_temp_region() recently into this script.
Don't know if it is worth trying to fit GridModule with use_temp_region(),
so closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3685#comment:3&gt;
