[GRASS-dev] [GRASS GIS] #3690: r.stats.quantile crashing with data linked through r.external
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Raster | Version: svn-
                                          | releasebranch74
Keywords: r.external, r.stats.quantile | CPU: Unspecified
Platform: Unspecified |
We discovered that r.stats.quantile crashes with data linked through
r.external (when importing the same data sets with r.in.gdal it works
fine).
It seems that a corruption occurs with GDAL?
GRASS 7.4.3svn (utm30N): > r.external input="covermap.tif" band=1
output=tmp15409185587112 --overwrite -o
Reading band 1 of 1...
r.external komplett. Link to raster map <tmp15409185587112> created.
GRASS 7.4.3svn (utm30N): > r.external input="basemap.tif" band=1
output=tmp15409185587113 --overwrite -oÜ
r.external komplett. Link to raster map <tmp15409185587113> created.
GRASS 7.4.3svn (utm30N): > r.stats.quantile -p base="tmp15409185587112"
cover="tmp15409185587113" bins="2000"
Computing histograms
  100%
Speicherzugriffsfehler (Speicherabzug geschrieben)
... i.e. Core dump.
Debugging:
GRASS 7.4.3svn (utm30N): > gdb r.stats.quantile
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.5) 7.11.1
(gdb) r -p base="tmp15409185587112" cover="tmp15409185587113" bins="2000"
Starting program: /home/user/src/grass-7.4.svn/dist.x86_64-pc-linux-
gnu/bin/r.stats.quantile -p base="tmp15409185587112"
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
  100%
   27%
Program received signal SIGSEGV, Segmentation fault.
0x0000000000401fa0 in get_slot_counts (basefile=0, coverfile=1) at
main.c:161
161 bc->slots[i]++;
(gdb) bt
#0 0x0000000000401fa0 in get_slot_counts (basefile=0, coverfile=1) at
main.c:161
#1 0x0000000000403c89 in main (argc=5, argv=0x7fffffffd878) at main.c:642
(gdb) bt full
main.c:161
         basebuf = 0x6c5760
         coverbuf = 0x6c6eb0
         bc = 0x6f3ab0
         row = 467
         col = 1305
         i = 0
         allnull = 0
         module = 0x7ffff7ba0ea8 <state+40>
         opt = {quant = 0x640ec0, perc = 0x641000, slots = 0x641140,
basemap = 0x7ffff7ba0f08 <state+136>, covermap = 0x640d80, output =
0x641280, file = 0x641440, fs = 0x641640}
         flag = {r = 0x7ffff7ba0ed8 <state+88>, p = 0x6426a0, t = 0x6426d0}
         basemap = 0x61edb0 "tmp15409185587112"
         covermap = 0x61ee80 "tmp15409185587113"
         outputs = 0x0
         fs = 0x7fffffffd72f "@"
         reclass = 0
         print = 1
         cover_fd = 1
         base_fd = 0
         range = {min = 1, max = 1061, first_time = 0}
         fprange = {min = 7.0767250061034996, max = 9.9984693527221999,
first_time = 0}
         i = 1
(gdb)
Looking at memory allocation and G_free() usage, I see that not all is
freed:
cd r.stats.quantile/
grep 'G_calloc\|G_free' main.c | grep bc
         bc->slots = G_calloc(bc->num_slots, sizeof(unsigned int));
         bc->bins = G_calloc(num_quants, sizeof(struct bin));
         bc->slot_bins = G_calloc(bc->num_slots, sizeof(unsigned char));
         G_free(bc->slots);
         bc->values = G_calloc(num_values, sizeof(DCELL));
         G_free(bc->slot_bins);
but I am not sure if that is related.
We can make the two GeoTIFF files offlist available.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690&gt;
Component: Raster | Version: svn-releasebranch74
Resolution: | Keywords: r.external, r.stats.quantile
Comment (by mmetz):
Replying to [ticket:3690 neteler]:
fine).
> 100%
> ... i.e. Core dump.
The above commands do not work for me because basemap and covermap are
swapped and the base map must be CELL type.
These commands
r.external input=covermap.tif band=1 output=covermap_ext
r.external input=basemap.tif band=1 output=basemap_ext
r.stats.quantile -p base=basemap_ext cover=covermap_ext bins=2000
work for me without segfault and valgrind does not find any memory
violations.
I am using GDAL 2.3.2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 mmetz]:
swapped
ops, maybe I flipped that while anonymising the data using the output from
the QGIS Processing log file.
Would it be possible to add a test for that?
> These commands
violations.
The machine causing problems is Linux Mint (Ubuntu). The versions I don't
have right now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 neteler]:
swapped
from the QGIS Processing log file.
This test exists already:
ERROR: The base map must be an integer (CELL) map
don't have right now.
Can you please test again on this machine, directly in GRASS, and ideally
with both GRASS 7.4 and 7.6?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.external, r.stats.quantile
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"73639" 73639]:
#!CommitTicketReference repository="" revision="73639"
r.external: do not rely on statistics stored in metadata, they can be
approximations (fixes #3690)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:4&gt;
Comment (by mmetz):
Replying to [comment:4 mmetz]:
These approximate statistics stored in metadata are a nightmare! The
stored maximum value in basemap is too low:
gdalinfo -mm basemap.tif
   Min=1.000 Max=1061.000 Computed Min/Max=1.000,1063.000
However, metadata say
TIFFTAG_SOFTWARE=GRASS GIS 7.4.3svn with GDAL 2.2.2
in which case min and max should not be set at all. That means some other
software has edited the metadata in basemap.tif, inserting approximate and
thus wrong values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:5&gt;
