#3694: WHERE statement in v.generalize do not work
Reporter: BastienFR | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.1
Keywords: v.generalize | CPU: x86-64
Platform: MSWindows |
The `WHERE` statement from `v.generalize` do not seem to work anymore.
Resolution: | Keywords: v.generalize
CPU: x86-64 | Platform: MSWindows
Comment (by mmetz):
Replying to [ticket:3694 BastienFR]:
Looking at the manual G7:v.generalize:
layer=string
Layer number or name ('-1' for all layers)
A single vector map can be connected to multiple database tables. This
number determines which table to use. When used with direct OGR access
this is the layer name.
Default: -1
By default all layers are processed, in which case the cats and where
options are ignored because they require a single layer to be selected.
Results are as expected when using `v.generalize layer=1 where="CNTY<1"
Note that a boundary is generalized as soon as any of the areas it belongs
to fulfils the where condition. In a topological vector model as in GRASS,
the modification of a single boundary results in the modification of two
areas.
Comment (by mmetz):
Replying to [comment:1 mmetz]:
> layer=string
This number determines which table to use. When used with direct OGR
access this is the layer name.
> Default: -1
FWIW, I have added a warning in trunk r73673 if the cats and where options
are ignored.
The QGIS interface description for v.generalize needs to be fixed to use
`layer=1`.
Comment (by BastienFR):
Thanks for your answer. I did try with the good option `layer=1` directly
in GRASS and it worked as expected. I'll update my question on
StackExchange to give the answer (or if you want to do it, I'll accept
your answer).
The fact the the QGIS v.generalize tool do not allow to set the `layer`
option even if allowing setting the `WHERE` statement, how or where should
we document the problem so it's fix there?
Comment (by mmetz):
Replying to [comment:3 BastienFR]:
directly in GRASS and it worked as expected. I'll update my question on
your answer).
You can update your question to give the answer, maybe with a link to the
manual and the (by now updated) tutorial
> However, note that your tutorial do not state that properly
(https://grasswiki.osgeo.org/wiki/V.generalize_tutorial#Gereneral_Parameters).
There is no `layer` option in the call given.
> v.generalize -c input=roads output=roads_douglas_reduction2
method=douglas_reduction threshold=0 reduction=50 type=line where="cat<3"
Thanks for pointing this out, now fixed.
The tutorial has been written for the initial version of v.generalize
where the default answer for the layer option was 1. The default has been
changed from 1 to -1 (all layers) in r39888 (9 years ago).
The QGIS interface description for v.generalize needs to have layer=1
hard-coded (not a user-option).
