#37: r.in.xyz increase region based on input data
Reporter: marisn | Owner: hamish
Type: enhancement | Status: reopened
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Comment (by hamish):
I will write a demonstration r.in.xyz.auto script providing the desired
functionality wrt bounds so we can test how other methods could work.
However, for this module picking your resolution (thus average number of
input points per cell bin) is *absolutely fundamental* to results and must
be chosen with care and supervision. This probably means a few trial
'r.in.xyz method=n' + 'r.univar n_map' steps to get it right. This is
unknowable information from the data which must be supplied by the user,
and the workflow is multi-step.
Solutions:
* We could use the current region resolution with bounds taken from
scanning step. In this case the user is 90% likely not to have considered
the resolution first and will get bad results or a out-of-memory error as
the resolution will be badly wrong. Also it means using a g.region step
first anyway, so we're not really that much better off.
* We could add a res= option for use with an optional auto-bounds setting
flag. I'm not very excited about adding new options and flags, but it's a
possibility. 'g.region -a' like code would need into the module and offset
region would be impossible (s=25 n=75 res=50).
* We could choose a default resolution that made the output like a
1000x1000 map. Lame.
I think that all these solution are to some extent poor and would be
little more consistent with other r.in.* modules than the current way. In
any case import from auto-scanned bounds should not be changed to be the
default, and custom subregion and resolution must remain possible. In
practice I have found that a cropping step is generally wanted, so it is
useful to combine it with this first import step.
Re consistency we just have to note that the module works on the current
region like other r. modules and not like other r.in. modules.
I would also note that this is all well discussed in the man page, with an
example.
still unconvinced,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/37#comment:10>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
