#3700: Enhancement of v.extract to include a new output_layer parameter
Reporter: jradinger | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: | CPU: Unspecified
Platform: All |
Based on a [http://osgeo-org.1560.x6.nabble.com/v-extract-and-layer-table-
settings-with-layer-2-td5387237.html mailing list discussion] I suggest an
enhancement of `v.extract` to include a new output_layer parameter.
This would be needed/useful when extracting features from a map from e.g.
layer 2 and the result should be map with a (single) layer 1. For example,
if features from layer=2 are extracted using current version of
`v.extract` the procedure is complicated and requires four steps because
`v.extract` does not change the the layer/table bindings:
1) `v.extract input=mymap1 layer=2 where='mycol=x' output=mymap2`
The resulting 'mymap2' has an attribute table connected to layer 2 and
there are no other layers (e.g. there is no layer 1, which is considered
in most grass tools as default layer).
2) `v.category option=chlayer layer='2,1' input=mymap2 output=mymap3`
3) `v.db.connect -d layer=2 map=mymap3`
4) `v.db.connect layer=1 map=mymap3 table=mymap3`
For such a task, the best would probably be some form of output_layer
parameter in `v.extract`, probably with a default of 1.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3700>
