[GRASS-dev] [GRASS GIS] #3707: vector module tests failing
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Vector | Version: svn-trunk
Keywords: v.what, v.db.select, v.profile, | CPU: Unspecified
  v.rast.stats, v.select |
Platform: Unspecified |
At time some vector module tests are failing:
   * AssertionError: actual argument is not a string
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.what/test_vwhat_ncspm/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.db.select/test_v_db_select/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.profile/test_v_profile/index.html
   * AssertionError: reference argument is not a string
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/scripts/v.rast.stats/test_v_rast_stats/index.html
   * ERROR: Only numeric column type is supported
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/lib/python/gunittest/test_assertions_vect/index.html
   * ERROR: Vector map <bridges> not found
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.select/test_v_select/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3707&gt;
Component: Tests | Version: svn-trunk
Resolution: | Keywords: v.what, v.db.select, v.profile,
       CPU: | v.rast.stats, v.select
  Unspecified | Platform: Unspecified
Changes (by neteler):
* component: Vector => Tests
Comment:
Entry page of tests:
http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3707#comment:1&gt;
