#3711: d.rast.edit GUI only starts with --ui
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Display | Version: svn-releasebranch76
Keywords: GUI | CPU: Unspecified
Platform: MSWindows |
trying to start d.rast.edit in the wxGUI console, a message pops up the
d.rast.edit isn't yet implemented in the wxGUI; just try to add it as a
command layer instead.
it come from frame.py:
def RunDisplayCmd(self, command):
"""Handles display commands.
:param command: command in a list
if not self.currentPage:
self.NewDisplay(show=True)
# here should be the d.* commands which are not layers
if command[0] == 'd.erase':
# rest of d.erase is ignored
self.GetLayerTree().DeleteAllLayers()
return
try:
# display GRASS commands
layertype = command2ltype[command[0]]
except KeyError:
GMessage(
parent=self, message=_(
"Command '%s' not yet implemented in the WxGUI. "
"Try adding it as a command layer instead.") %
command[0])
return
d.rast.edit --ui'' open the GUI
tested with
System Info
GRASS version: 7.7.svn
GRASS SVN revision: r73796
Build date: 2018-12-14
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17763 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3711>
