#3715: v.out.ogr segfault with GPKG output
Reporter: vince | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.2
Keywords: v.out.ogr | CPU: x86-64
Platform: MacOSX |
This happens while using GRASS in the QGIS toolbox.
A r.contour operation runs fine, but when the result is about to be saved
in a GPKG file, v.out.ogr crashes.
Backtrace:
1 libsqlite3.dylib dbMallocRawFinish + 17
2 libsqlite3.dylib sqlite3FindFunction + 886
3 libsqlite3.dylib sqlite3CreateFunc + 499
4 libsqlite3.dylib sqlite3_create_function_v2 + 488
5 libspatialite.7.dylib register_spatialite_sql_functions + 68
6 libspatialite.7.dylib spatialite_init_ex + 52
7 libgdal.20.dylib OGRSQLiteBaseDataSource::InitNewSpatialite()
+ 302
8 libgdal.20.dylib GDALGeoPackageDataset::InstallSQLFunctions()
+ 19
9 libgdal.20.dylib GDALGeoPackageDataset::Create(char const*,
int, int, int, GDALDataType, char**) + 485
10 libgdal.20.dylib OGRGeoPackageDriverCreate(char const*, int,
int, int, GDALDataType, char**) + 159
11 libgdal.20.dylib GDALDriver::Create(char const*, int, int,
int, GDALDataType, char**) + 1063
12 libgdal.20.dylib OGR_Dr_CreateDataSource + 47
13 v.out.ogr main + 3564
I have upgraded to spatialite 5.0.0 beta0 in hope that would solve the
problem, but no dice. Also, I run GDAL 2.3.2.
Saving as Shapefile works fine, though, so this is a mere inconvenience
rather than a roadblock.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3715>
