#3720: temporal modules fail with python 3
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.8.0
Component: Temporal | Version: svn-trunk
Keywords: temporal, python3 | CPU: x86-64
Platform: Linux |
Temporal modules do not work with python3 in virtualenv. In a mapset where
I have strds, I run `t.list` and I get:
Process Process-2:
File "/usr/lib64/python3.6/multiprocessing/process.py", line 258, in
_bootstrap
self.run()
File "/usr/lib64/python3.6/multiprocessing/process.py", line 93, in run
self._target(*self._args, **self._kwargs)
File "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 959, in
c_library_server
functions[data[0]](lock, conn, data)
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 241, in
_get_driver_name
drstring = libtgis.tgis_get_mapset_driver_name(mapset)
ctypes.ArgumentError: argument 1: <class 'TypeError'>: expected LP_c_char
instance, got bytes
WARNING:root:Needed to restart the libgis server, caller: Server check
thread
gnu/etc/python/grass/pygrass/rpc/base.py", line 161, in safe_receive
ret = self.client_conn.recv()
File "/usr/lib64/python3.6/multiprocessing/connection.py", line 250, in
recv
buf = self._recv_bytes()
File "/usr/lib64/python3.6/multiprocessing/connection.py", line 407, in
_recv_bytes
buf = self._recv(4)
File "/usr/lib64/python3.6/multiprocessing/connection.py", line 383, in
_recv
raise EOFError
EOFError
During handling of the above exception, another exception occurred:
gnu/scripts/t.list", line 186, in <module>
main()
gnu/scripts/t.list", line 112, in main
tgis.init()
gnu/etc/python/grass/temporal/core.py", line 571, in init
driver_string = ciface.get_driver_name()
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 1487, in
get_driver_name
return self.safe_receive("get_driver_name")
gnu/etc/python/grass/pygrass/rpc/base.py", line 168, in safe_receive
raise FatalError("Exception raised: " + str(e) + " Message: " +
message)
grass.exceptions.FatalError: Exception raised: Message: get_driver_name
thread
Same if I try to create a stds with `t.create`, ask info with `t.info` and
so on...
All temporal functionality is up and running in 76 release branch though.
See also #3682
Ticket URL: <https://trac.osgeo.org/grass/ticket/3720>
