[GRASS-dev] [GRASS GIS] #3723: winGRASS7.7.svn - python 3 issues
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Python | Version: svn-trunk
Keywords: python3, py3, wingrass | CPU: Unspecified
Platform: MSWindows |
tested with a self compiled winGRASS7.7.svn with python 3
C:\>g.version -e -g
version=7.7.svn
date=2019
revision=r73896M
build_date=2019-01-01
build_platform=x86_64-w64-mingw32
build_off_t_size=8
proj4=5.2.0
gdal=2.4.0
geos=3.7.0
sqlite=3.26.0
C:\>grass77svn --text
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files...
           __________ ___ __________ _______________
          / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
         / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
        \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.7.svn (r73896M)
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
Start the GUI with: g.gui wxpython
When ready to quit enter: exit
Microsoft Windows [Version 10.0.17763.195]
(c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>python
Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit
(AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
then g.gui wxpython errors in
C:\>g.gui wxpython
Launching <wxpython> GUI in the background, please wait...
   File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py",
line 41, in <module>
     import __builtin__
ModuleNotFoundError: No module named '__builtin__'
During handling of the above exception, another exception occurred:
   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn/gui/wxpython/wxgui.py", line
27, in <module>
     from core import globalvar
   File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\globalvar.py",
line 31, in <module>
     from core.debug import Debug
   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\debug.py",
line 25, in <module>
     import grass.script as grass
   File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\grass\script\__init__.py",
line 5, in <module>
     from .core import *
   File
line 47, in <module>
     from os import environb as environ
ImportError: cannot import name 'environb' from 'os'
(C:\OSGEO4~1\apps\Python37\lib\os.py)
it seems that core.py hangs around
try:
     # python2
     import __builtin__
     __builtin__.__dict__['_'] =
__builtin__.__dict__['_'].__self__.ugettext
except ImportError:
     # python3
     import builtins as __builtin__
     unicode = str
     __builtin__.__dict__['_'] = __builtin__.__dict__['_'].__self__.gettext
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723&gt;
Resolution: | Keywords: python3, py3, wingrass
       CPU: Unspecified | Platform: MSWindows
Comment (by hellik):
Replying to [ticket:3723 hellik]:
regarding the environb issue, see
https://docs.python.org/3/library/os.html
  os.environb¶
     Bytes version of environ: a mapping object representing the
environment as byte strings. environ and environb are synchronized (modify
environb updates environ, and vice versa).
     environb is only available if supports_bytes_environ is True.
https://docs.python.org/3/library/os.html#os.supports_bytes_environ
     True if the native OS type of the environment is bytes (eg. False on
Windows).
it seems this isn't available in windows
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:1&gt;
Replying to [comment:1 hellik]:
> os.environb¶
Windows).
see (GRASS related):
https://stackoverflow.com/questions/52269281/fix-import-error-on-using-
environb-in-python#
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:2&gt;
#3723: winGRASS7.7.svn - core.py - python 3 issues
  Priority: blocker | Milestone: 7.8.0
Changes (by hellik):
* priority: normal => blocker
* milestone: => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:3&gt;
Comment (by martinl):
In [changeset:"73906" 73906]:
#!CommitTicketReference repository="" revision="73906"
avoid usage of os.environb, inspired by
environb-in-python, see #3723
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:4&gt;
Replying to [comment:2 hellik]:
environb-in-python#
suggested modification applied in r73906 (for better testing). It will
appear in winGRASS build no. 364+.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:5&gt;
Replying to [comment:5 martinl]:
using-environb-in-python#
tested with
Welcome to GRASS GIS 7.7.svn (r73906)
C:\>g.gui wxpython
C:\>Traceback (most recent call last):
   File "C:\OSGeo4W\apps\grass\grass-7.7.svn/gui/wxpython/wxgui.py", line
27, in
<module>
   File
"C:\OSGeo4W\apps\grass\grass-7.7.svn\gui\wxpython\core\globalvar.py", lin
e 31, in <module>
   File "C:\OSGeo4W\apps\grass\grass-7.7.svn\gui\wxpython\core\debug.py",
line 77
, in <module>
     Debug = DebugMsg()
line 39
, in __init__
     self.SetLevel()
line 45
, in SetLevel
     self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
   File
"C:\OSGeo4W\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py", li
ne 1082, in gisenv
     s = read_command("g.gisenv", flags='n', env=env)
   File
ne 502, in read_command
     process = pipe_command(*args, **kwargs)
   File
ne 471, in pipe_command
     return start_command(*args, **kwargs)
   File
ne 396, in start_command
     if debug_level() > 0:
   File
ne 1670, in debug_level
     _debug_level = int(gisenv().get('DEBUG', 0))
   File
ne 1082, in gisenv
   File
   File
   File
ne 401, in start_command
     return Popen(args, **popts)
   File
ne 66, in __init__
     cmd = shutil_which(args[0])
   File
ne 220, in shutil_which
     if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
   File
ne 220, in <genexpr>
TypeError: endswith first arg must be bytes or a tuple of bytes, not str
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:6&gt;
Replying to [comment:6 hellik]:
> File
now also tested with the OSGeo4W 64bit version.
C:\>g.version -g
version=7.7.svn
date=2019
revision=r73906
build_date=2019-01-04
build_off_t_size=8
same error
C:\>g.gui wxpython
27, in <module>
   File
line 77, in <module>
     Debug = DebugMsg()
line 39, in __init__
     self.SetLevel()
line 45, in SetLevel
   File
line 1082, in gisenv
   File
line 502, in read_command
   File
line 471, in pipe_command
   File
line 396, in start_command
   File
line 1670, in debug_level
   File
   File
   File
   File
line 401, in start_command
   File
line 66, in __init__
   File
line 220, in shutil_which
   File
line 220, in <genexpr>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:7&gt;
In [changeset:"73930" 73930]:
#!CommitTicketReference repository="" revision="73930"
wingrass77 core python3 issues, see #3723
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:8&gt;
Reported issue should be fixed in r73930. You can test it with WinGRASS
daily build no. 372+. See related #3731
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: python3, py3, wingrass
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Build no.372 tested. Original issue seems to be fixed. Feel free to reopen
if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:10&gt;
Build no. 375 fails with new issues
   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\wxgui.py", line
103, in OnInit
     workspace=self.workspaceFile)
   File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\frame.py",
line 131, in __init__
     self._moduleTreeBuilder =
LayerManagerModuleTree(message_handler=add_menu_error)
   File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\menudata.py", line
69, in __init__
     message_handler=message_handler)
   File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\menutree.py", line
72, in __init__
     xmlTree = etree.parse(filename)
   File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line
1197, in parse
     tree.parse(source, parser)
   File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 598,
in parse
     self._root = parser._parse_whole(source)
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Reason:
`C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\xml\module_tree_menudata.xml`
is empty.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:11&gt;
