GDAL
January 12, 2019, 11:40am
1
#3732: wingrass: change instalation target
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.6.0
Component: Installation | Version: unspecified
Keywords: wingrass | CPU: Unspecified
Platform: Unspecified |
Currently GRASS is installed by OSGeo4W into `apps/grass/grass-
major.minor.release`. Executable is called `grass.majorminor.bat`. Eg.
apps/grass/grass-7.4.4
bin/grass74.bat
Changing installation directory for each release is not practical from
QGIS POV.
Suggestion from ML (https://lists.osgeo.org/pipermail/grass-
dev/2019-January/090919.html):
1.
bin/grass74.bat
+ similar to Debian packaging policy
- QGIS needs to be updated on every minor version
2.
apps/grass/grass7
bin/grass7.bat
+ QGIS updated on GRASS major release only
+ possible to install two major GRASS versions in parallel (like `grass6`
package)
3.
apps/grass
bin/grass.bat
- not possible to install two GRASS major version in parallel.
+ no need to update QGIS at all
Related versions for daily package:
apps/grass/grass-daily-7.4
bin/grass-daily74.bat
apps/grass/grass-daily7
bin/grass-daily7.bat
apps/grass-daily
bin/grass-daily.bat
Any comments/suggestions?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
January 12, 2019, 2:20pm
2
Resolution: | Keywords: wingrass
Comment (by hellik):
I'm in favour of option 1:
bin/grass74.bat
it's a good compromise between stability and flexibility.
as we don't have that much minor releases in a year, not much work on QGIS
side. but we have the flexibility to have 2 minor releases side by side if
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:1> ;
GDAL
January 26, 2019, 8:35pm
3
Priority: normal | Milestone: 7.6.1
Comment (by martinl):
In [changeset:"74027" 74027]:
#!CommitTicketReference repository="" revision="74027"
wingrass: change instalation target, see #3732
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:3> ;
GDAL
January 26, 2019, 10:12pm
4
In [changeset:"74028" 74028]:
#!CommitTicketReference repository="" revision="74028"
wingrass: change instalation target also for standalone installer, see
#3732
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:4> ;
GDAL
January 27, 2019, 11:57am
5
In [changeset:"74029" 74029]:
#!CommitTicketReference repository="" revision="74029"
configure: change instalation target for osgeo4w, see #3732
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:5> ;
GDAL
January 28, 2019, 9:56am
6
In [changeset:"74038" 74038]:
#!CommitTicketReference repository="" revision="74038"
wingrass: change instalation target, see #3732 (g76: merge r74027:74029
from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:6> ;
GDAL
January 28, 2019, 10:01am
7
Type: task | Status: closed
Resolution: fixed | Keywords: wingrass
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Changes applied in trunk and releasebranch_7_6:
In OSGeo4W GRASS is installed into `apps\grass\grass<major><minor>`
By standalone installator into `Program Files\GRASS GIS <major>.<minor>`.
Closing as fixed. Feel free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3732#comment:7> ;
