[GRASS-dev] [GRASS GIS] #3735: WinGRASS: g.extension does not remove the .bat file
Reporter: Nikos Alexandris | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: MSWindows |
When using `g.extension` and performing an "un-installation" of an
installed add-on, the respective `.bat` file is not removed.
For example, using the GUI under '''Settings''' > '''Addons extensions'''
> '''Install extensions from addons''' the command that is executed is:
g.extension extension=r.estimap.recreation url=
Downloading precompiled GRASS Addons <r.estimap.recreation>...
Updating addons metadata file...
Installation of <r.estimap.recreation> successfully finished
This installs the selected add-on in to
  `C:\Users\nik\AppData\Roaming\GRASS7\addons\bin`
and `C:\Users\nik\AppData\Roaming\GRASS7\addons\scripts`.
Using the GUI to uninstall the add-on, removes only the Python script
under
The `.bat` file under
   `C:\Users\nik\AppData\Roaming\GRASS7\addons\bin\`
remains untouched.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3735&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows
Comment (by Nikos Alexandris):
Any activity on this?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3735#comment:1&gt;
