#3737: Testsuite gunittest/multirunner.py: TypeError: str expected, not bytes
Reporter: AnikaBettge | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: Python3, testsuite
CPU: x86-64 | Platform: Linux
Comment (by AnikaBettge):
Cleaning up default sqlite database ...
Cleaning up temporary files...
raster3d_lib_test from ./lib/raster3d failed (3 tests failed)
test_assertions from ./lib/python/gunittest failed (3 tests failed)
test_checkers from ./lib/python/gunittest failed (1 test failed)
test_gmodules from ./lib/python/gunittest failed (4 tests failed)
test_assertions_vect from ./lib/python/gunittest failed (7 tests failed)
test_assertions_rast3d from ./lib/python/gunittest failed (2 tests failed)
test_module_assertions from ./lib/python/gunittest failed (2 tests failed)
test_doctests from ./lib/python/gunittest failed (2 tests failed)
unittests_temporal_raster_conditionals from ./lib/python/temporal failed
(50 tests failed)
unittests_temporal_raster_conditionals_complement_else from
./lib/python/temporal failed (4 tests failed)
unittests_temporal_vector_algebra from ./lib/python/temporal failed (14
tests failed)
unittests_temporal_conditionals from ./lib/python/temporal failed (34
tests failed)
unittests_temporal_raster_algebra_grs from ./lib/python/temporal failed
(13 tests failed)
unittests_temporal_algebra_grs from ./lib/python/temporal failed (6 tests
failed)
unittests_temporal_raster_algebra from ./lib/python/temporal failed (80
tests failed)
unittests_temporal_raster3d_algebra from ./lib/python/temporal failed (4
tests failed)
unittests_temporal_raster_algebra_equal_ts from ./lib/python/temporal
failed (10 tests failed)
unittests_temporal_algebra from ./lib/python/temporal failed (39 tests
failed)
unittests_temporal_raster_algebra_spatial_topology from
./lib/python/temporal failed (12 tests failed)
test_doctests from ./lib/python/temporal failed (15 tests failed)
unittests_temporal_algebra_mixed_stds from ./lib/python/temporal failed (9
tests failed)
test_doctests from ./lib/python/script failed (1 test failed)
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/home/abettge/src/grass-7.7.svn/dist.x86_64-pc-linux-
gnu/etc/python/grass/gunittest/main.py", line 178, in <module>
sys.exit(main())
gnu/etc/python/grass/gunittest/main.py", line 174, in main
results_dir=results_dir)
gnu/etc/python/grass/gunittest/invoker.py", line 237, in run_in_location
gisdbase=gisdbase, location=location)
gnu/etc/python/grass/gunittest/invoker.py", line 193, in _run_test_module
self._file_anonymizer.anonymize([stdout_path, stderr_path])
gnu/etc/python/grass/gunittest/reporters.py", line 103, in anonymize
replace_in_file(filename, path + path_end, '')
gnu/etc/python/grass/gunittest/reporters.py", line 61, in replace_in_file
for line in old_file:
File "/home/abettge/src/grass-7.7.svn/grasspy3/lib/python3.6/codecs.py",
line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc3 in position 439:
invalid continuation byte
GRASS Location <other_location> does not exist in GRASS Database
</home/abettge/grassdata/tests-grassdata>
File
"/home/abettge/src/grass-7.7.svn/lib/python/gunittest/multireport.py",
line 28, in <module>
from grass.gunittest.checkers import text_to_keyvalue
gnu/etc/python/grass/gunittest/checkers.py", line 18, in <module>
from grass.script.core import KeyValue
gnu/etc/python/grass/script/__init__.py", line 5, in <module>
from .core import *
gnu/etc/python/grass/script/core.py", line 38, in <module>
gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"),
'locale'))
File
"/home/abettge/src/grass-7.7.svn/grasspy3/lib/python3.6/posixpath.py",
line 80, in join
a = os.fspath(a)
TypeError: expected str, bytes or os.PathLike object, not NoneType
grass77 --config svn_revision
74046M
Ticket URL: <https://trac.osgeo.org/grass/ticket/3737#comment:8>
