[GRASS-dev] [GRASS GIS] #3744: Vector query error
Reporter: balagates | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-releasebranch76
Keywords: vector query error JSON | CPU: OSX/Intel
Platform: MacOSX |
For some vector elements I get an error
Failed to query vector map(s) <mrds_id@brett>. Check database settings and
topology.
Reason: ""}}]}]}]}
ScriptError: v.what output is not valid JSON format:
Within this vector other points query successfully. My vector mrds_id is
Mineral Resource Data System records for mines in Idaho. Within Grass the
data is in a sqlite database. Using sqlitebrowser I see no obvious
problems on elements that generate query errors.
I suspect the failure is either related to 1) the length of the vector
info (number of elements, number of characters, etc) or 2) some special
characters within the vector info (maybe parenthesis). The failure
happens on maybe 10% of the vector points.
A picture of the error is attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/3744&gt;
Resolution: | Keywords: vector query error JSON
       CPU: OSX/Intel | Platform: MacOSX
Changes (by balagates):
* Attachment "vector_query_error.png" added.
screen print of vector query error
Comment (by mmetz):
Replying to [ticket:3744 balagates]:
and topology.
> Reason: ""}}]}]}]}
is Mineral Resource Data System records for mines in Idaho. Within Grass
the data is in a sqlite database. Using sqlitebrowser I see no obvious
The reason for the failure is most probably the entry for "reporter" which
has double quotes within double quotes, causing a parse error. A solution
could be to escape double quotes within a text field, e.g.
"reporter":"\"Peters, DonaldW.\",\"Loen, Jeffrey S. (Pearson, Robert
C.)\""
This would need to be fixed in v.what, somewhere around what.c:L93.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3744#comment:1&gt;
Comment (by mmetz):
Replying to [comment:1 mmetz]:
Should be fixed in trunk r74048
Ticket URL: <https://trac.osgeo.org/grass/ticket/3744#comment:2&gt;
