[GRASS-dev] [GRASS GIS] #3756: r.watershed: flow accumulation wrong with edge contamination
Reporter: itati01 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-
Keywords: r.watershed, flow accumulation, | releasebranch76
  edge contamination | CPU: Unspecified
Platform: Unspecified |
Dear developers,
I compared the results of the flow accumulation (=facc) in the independent
Python module ''pysheds'' to '''r.watershed''' with the '''flag -a'''. The
input of ''pysheds'' was the flow direction (=fdr, D8) created by
'''r.watershed''', so the resulting rasters should be identical.
The difference in facc (=pysheds - r.watershed) is zero for most of the
raster, except for raster cells affected by edge contamination where
''pysheds'' overestimates facc compared to r.watershed. At first, I
suspected an error in the much younger pysheds, however r.watershed seems
to be the culprit.
Note: The catchment I use is crossed by a channel, which in turn is
crossed by streams. I removed this channel by setting the DEM to nodata
except for the crossings + some buffer. So, I cannot exclude edge-
contaminated cells.
Small differences are along the majority of the nodata values and they
increase downstream. The source of the problem could be a) a mis-
interpretation of negative fdr or b) wrong facc in case of edge
contamination (or unexpected behaviour). For ''pysheds'', I assumed that
the absolute value indicates the direction and the negative sign indicates
edge contamination. I was puzzled about the output of '''d.rast.arrow
type=drainage''': the arrows are shifted, e.g. -2 was identical to +1 not
+2. Also tested it with ''pysheds'' to no avail.
(By the way, the output of '''d.rast.arrow''' looks wrong, e.g. the red
rectangles in figure 1. If someone confirms this error, I can open a
separate ticket for this issue. The error in '''d.rast.arrow''' would be
here:
if (...map_type == 5) {
     aspect_c = (int)(aspect_f + 0.5);
Most likely it is about the cumulation of negative values. Take the
rectangle in figure 2 as an example. It contains raster cells 1-9, I am
counting row-wise starting with the top left cell. One route is 8 + 9 -> 6
+ 1 -> 2 -> Channel in blue. ''Pyshed'' produces what I expect: facc == 3
for cell6 and facc == 5 for cell2, while '''r.watershed''' calculates for
all cells +1, or -1 without the flag -a.
The reason is presumably: cells 8, 9 and 1 are edge contaminated (i.e.
facc is turned to -1). So, for cell 6: facc = -1 + -1 + 1 = -1 (1 is the
default weight for all cells). The calculation for cell 2 is identical.
I suggest to ''subtract'' not to ''add'' the weights in case of edge-
contaminated upslope cells.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756&gt;
Component: Raster | Version: svn-releasebranch76
Resolution: | Keywords: r.watershed, flow accumulation,
       CPU: | edge contamination
  Unspecified | Platform: Unspecified
Changes (by itati01):
* Attachment "d_rast_error.png" added.
Figure 1: Output of d.rast.arrow with the flow direction as input, the
blue rectangle similar to Figure 2, red rectangles indicate wrong
interpretation of negative flow directions
* Attachment "error_facc_grass.png" added.
Figure 2: Unexpected flow accumulation, r.watershed returns 1 for all
cells within the rectangle, nodata in blue
Comment (by mmetz):
Regarding edge cells (cells bordering a nodata cell), flow can not be
distributed and thus not accumulated because of these neighbor cells with
nodata. Flow distribution can not be determined if any neighbor is nodata.
Consequently, flow accumulation for cells where any neighbor is nodata is
set to -1. Exceptions are cells with a nodata neighbor that receive
surface flow from cells that do not have a nodata neighbor.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:1&gt;
Comment (by itati01):
Dear Markus,
Thank you for your comment.
I understand the problem with nodata cells in flow accumulation and would
normally drop edge-contaminated cells. However, this is an exceptional use
case, with nodata cells within the catchment. So, I used the flag -a
hoping to obtain the number of upslope cells. I would like to ignore the
nodata cells, and can actually do so because they form a channel (which I
burned into the DEM to avoid artifical inflow from outside the watershed).
So, there should really be no flow out of these nodata cells.
According to your explanation, my flow accumulation of -/+1 for cells 2
and 6 within the rectangle in Figure 2 must be wrong. Cell 6, i.e. the 3rd
cell in the 2nd row, only receives input from the 2 cells in row 3 which
were correctly - as neighbors of nodata cells - set to -1. So, the weight
of cell 6 should also be -1 (only flow from cells with nodata as neighbor)
and the flow accumulation should be -/+3 - what I hoped to obtain.
However, even with "regular" inflow, it would be nice to have an option to
ignore edge contamination (feature request?). Just assume, we have 4
upslope cells, of which 2 are edge contaminated. So, currently, we would
get a flow accumulation of 1, not 5?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 itati01]:
> Dear Markus,
would normally drop edge-contaminated cells. However, this is an
exceptional use case, with nodata cells within the catchment.
The same rule applies here too: any cell bordering a nodata cell does not
distribute flow because it can not be determined where flow should be
distributed to.
> So, I used the flag -a hoping to obtain the number of upslope cells.
The -a flag simply converts negative flow accumulation (receiving an
unknown amount of flow) to positive flow accumulation.
> I would like to ignore the nodata cells, and can actually do so because
they form a channel (which I burned into the DEM to avoid artifical inflow
from outside the watershed). So, there should really be no flow out of
these nodata cells.
This is correct, there will be no flow out of nodata cells. But there is
an unknown amount of flow from nodata cells.
The other cells that might contribute to cell 6 are cells 8 and 9, both
are edge-contaminated, thus cells 8 and 9 can not distribute flow, and
thus flow accumulation of cell 6 is -1.
to ignore edge contamination (feature request?).
This would cause flow accumulation to follow edge-contaminated cells which
is wrong. This could be easily demonstrated be setting the current region
to a small subregion, calculate flow accumulation, then enlarge the
region, calculate flow accumulation again, and compare the two results for
flow accumulation. The result for the subregion would be obviously wrong.
> Just assume, we have 4 upslope cells, of which 2 are edge contaminated.
So, currently, we would get a flow accumulation of 1, not 5?
No, if the other 2 upslope cells are not edge-contaminated, we would get a
flow accumulation of 3 because the not edge-contaminated cells are allowed
to distribute flow, also towards edge-contaminated cells.
Regarding edge-contaminated cells, flow accumulation and flow direction
are treated differently. Edge-contaminated cells can not distribute flow
because this can cause flow to incorrectly follow edge-contaminated cells.
Flow direction for edge-contaminated cells is set to another not-nodata
cell if possible: the other cell is downstream, i.e. has a lower elevation
value. The reason is that edge-contaminated cells most likely belong to
the same catchment like a neighboring lower lying cell. Otherwise all
edge-contaminated cells that do not receive flow accumulation from not
edge-contaminated cells would form isolated single-cell catchments.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:3&gt;
Your first answer explained already everything. Thank you very much for
this exhaustive explanation. I had assumed that negative values are also
cumulated. So, I will close this ticket and have to find some other way
without setting channel cells to nodata.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.watershed, flow accumulation,
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:5&gt;
