[GRASS-dev] [GRASS GIS] #3757: Python3: range vs xrange
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python | Version: svn-trunk
Keywords: python3 | CPU: Unspecified
Platform: Unspecified |
In r74088 xrange() was changed to range(). If that change is fine, should
these other xrange() usages also be changed?
ag --python " in xrange"
doc/python/raster_example_ctypes.py
67:for row_n in xrange(rows):
lib/python/temporal/abstract_space_time_dataset.py
1146: >>> for i in xrange(3):
lib/python/temporal/spatio_temporal_relationships.py
423:# for i in xrange(len(maps)):
425:# for j in xrange(offset, len(maps)):
lib/python/pygrass/modules/interface/module.py
64: >>> for i in xrange(5):
87: >>> for i in xrange(5):
111: >>> for i in xrange(3):
lib/python/pygrass/raster/__init__.py
412: >>> for row in xrange(map_a.info.rows):
442: >>> for i in xrange(4):
479: >>> for row in xrange(map_a.info.rows):
480: ... for col in xrange(map_a.info.cols):
lib/python/pygrass/vector/basic.py
384: >>> for cat in xrange(100, 110): cats.set(cat, layer=cat-50)
lib/python/pygrass/vector/__init__.py
87: #return (self.read(f_id) for f_id in
xrange(self.num_of_features()))
Ticket URL: <https://trac.osgeo.org/grass/ticket/3757&gt;
Resolution: | Keywords: python3
Comment (by pmav99):
Python 2 has both {{{range()}}} and {{{xrange()}}}.
In Python 3, {{{range()}}} has been removed and {{{xrange()}}} has been
renamed to {{{range()}}}.
So any code using {{{xrange()}}} is not Python 3 compatible, so the answer
is yes {{{xrange()}}} needs to be replaced by {{{range()}}}. This does
lead to bigger RAM usage ({{{range()}}} creates a list while
{{{xrange()}}} creates an iterator, although in the vast majority of the
cases the impact is negligible (and when it isn't you should probably
rethink your algorithms).
The alternative is to introduce a "compatibility layer". E.g.
import sys
if sys.version_info.major < 3:
     range = xrange
but this needs to be used in every module (or added to a {{{compat.py}}}
module and imported from any other module. Moreover, this can break
something (if people were abusing {{{range()}}} that is).
All that being said, when cross-version compatibility is required it is
usually a good idea to use either six and/or future. I believe six is
already being pulled by GRASS dependencies (matptlotlib if memory serves).
https://pypi.org/project/six/
https://pypi.org/project/future/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3757#comment:1&gt;
Comment (by annakrat):
For the record, r74100 already replaces xrange with range in all important
places. All these usages left are in documentation/comments so it's less
important, I didn't do it mainly because I have some local changes so it
was inconvenient.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3757#comment:2&gt;
There are some more instances of xrange:
$ ag xrange --python -l
scripts/i.spectral/i.spectral.py
gui/wxpython/timeline/frame.py
gui/wxpython/nviz/wxnviz.py
gui/wxpython/iclass/plots.py
gui/wxpython/gui_core/wxlibplot.py
gui/wxpython/tplot/frame.py
temporal/t.rast.accdetect/t.rast.accdetect.py
tools/ppmrotate.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3757#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: python3
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"74128" 74128]:
#!CommitTicketReference repository="" revision="74128"
fix #3757: replace xrange with range
Ticket URL: <https://trac.osgeo.org/grass/ticket/3757#comment:4&gt;
