[GRASS-dev] [GRASS GIS] #3761: Verbosity of g.extension when using the -f flag
Reporter: Nikos Alexandris | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: g.extension | CPU: Unspecified
Platform: Unspecified |
In `g.extension`, in the `def remove_extension()` function, there is:
     if force:
         grass.verbose(_("List of removed files:"))
     else:
         grass.info(_("Files to be removed:"))
and
     if force:
         grass.message(_("Updating addons metadata file..."))
         remove_extension_xml(mlist)
         grass.message(_("Extension <%s> successfully uninstalled.") %
                       options['extension'])
This is not correct in my humble view. In case of using the `-f` flag,
the messages will be emitted regardless of any successful or non-
successful execution of the `remove_extension_xml` function which in turn
can be misleading.
I suggest these messages to be integrated in the functions for which they
report whatever they report. I have no solution to propose yet, but this
ticket serves to highlight the problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3761&gt;
Component: Default | Version: unspecified
Resolution: | Keywords: g.extension
Changes (by martinl):
* component: Addons => Default
Ticket URL: <https://trac.osgeo.org/grass/ticket/3761#comment:1&gt;
Comment (by Nikos Alexandris):
Also here:
https://github.com/OSGeo/grass/blob/9d140ebe89995a8e698e1b9d19f18b7c7387b64c/scripts/g.extension/g.extension.py#L1401
Better to state something is done after it is done. Else, change the
message.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3761#comment:3&gt;
