#3767: A better i/o system for the r.li family
Reporter: SteGobbi | Owner: grass-dev@…
Priority: normal | Milestone: 7.8.0
Component: Imagery | Version: unspecified
Keywords: Landscape analysis, r.li, patch | CPU: All
Platform: All |
Hello,
in my research activity i'm currently working with the "suite" r.li.
The output given by these commands is different if in the setup
(g.gui.rlisetup) we chose the "moving window" or the "whole map" option.
In the first case GRASS will write into the
Users\user1\AppData\Roaming\GRASS7\rli subfolder a very simple parseable
file containing the results of the landscape analysis. A first improvement
would be to modify the daemon.h file of the r.li family and allow GRASS to
write this file in the group folder of the raster image we are studying.
Which raises another issue: should the daemon be allowed to create a group
folder in the current location containing the ref to the analysed map and
the output file of the r.li module (in case the user hasn't set up a group
folder)?
The second case is: whole map is set as count method.
In this case a raster map is created which structure depends on the r.li
module we are working on, but the file containing the numerical results is
not generated. Another enhancement would be to generate anyway this file,
since the landscape analysis is supposed to give as output a numerical
index.
I would propose these two improvements for these modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3767>
