#3769: [testsuite] Do not hardcode the path of the GRASSSRC
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
The hardcoded path makes it difficult to run the testsuite without
modifying the configuration file. By using a relative path, anyone can
run the testuite without any modifications.
Original PR: https://github.com/GRASS-GIS/grass-ci/pull/5
Index: testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
--- testsuite/examples/test_framework_GRASS_GIS_with_NC.conf (revision
74152)
+++ testsuite/examples/test_framework_GRASS_GIS_with_NC.conf (working
copy)
@@ -3,7 +3,7 @@
# name of binary:
GRASSBIN=grass77
# source code directory as full path:
-GRASSSRC="$HOME/software/grass77"
+GRASSSRC="$(realpath ../../)"
# temporary grassdata directory
GRASSDATA="$HOME/grassdata/tests-grassdata"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3769>
