[GRASS-dev] [GRASS GIS] #377: gis.m/Map Display fails to handle vector layers with multiple databse layers
layers
Reporter: ploewe | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Tcl | Version: 6.3.0
Keywords: gis.m database query | Platform: Linux
      Cpu: x86-32 |
GRASS 6.3 gives strange effects when one is attempting to query or display
data from database layers greater than 1. This can be reproduced.
Example:
A polygon layer has been connected (in postgres) to two tables in layer 1
and layer 2:
GRASS 6.3.0 (meteo):~ > v.db.connect -p map=counties_pie01
Vector map <counties_pie01> is connected by:
layer <1> table <counties_pie01> in database <host=localhost,dbname=meteo>
through driver <pg> with key <cat>
layer <2> table <counties_pie01_a> in database
<host=localhost,dbname=meteo> through driver <pg> with key <cat>
The layer can be displayed in a map display, including its centroids.
While the "Layer for labels"/"Layer for query" is set to 1 (default),
performance is normal.
Hell breaks loose when the "Layer for query" is set to "2": Out of a
sudden all centroids and filled areas disappear from from the map display
(polygon outlines are still displayed).
The phenomena for "Layer for label"=2 are less severe: A "Attribute col
for labels" from the second table is just ignored, while polygon outlines,
area fills and centroids are properly rendered.
The gis.m output window does not provide any error messages or warnings
while these phenomena occur.
Ticket URL: <http://trac.osgeo.org/grass/ticket/377&gt;
layers
Resolution: | Keywords: gis.m database query
  Platform: Linux | Cpu: x86-32
Comment (by mlennert):
Replying to [ticket:377 ploewe]:
display data from database layers greater than 1. This can be reproduced.
> Example:
1 and layer 2:
Could you give us the output of v.category option=report ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:1&gt;
-------- Original-Nachricht --------
Datum: Fri, 21 Nov 2008 15:35:45 -0000
Von: "GRASS GIS" <trac@osgeo.org>
An:
Betreff: Re: [GRASS GIS] #377: gis.m/Map Display fails to handle vector layers with multiple databse layers
databse
layers
> Example:
1 and layer 2:
v.category input=counties_pie01 option=report layer=1
Layer / table: 1 / counties_pie01
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 558 1 439
area 0 0 0
all 558 1 439
v.category input=counties_pie01 option=report layer=2
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 558 1 439
area 0 0 0
all 558 1 439
HTH,
Peter
Moritz
Dr. Peter Löwe
<peter.loewe@gmx.de>
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
2008/11/24 "Peter Löwe" <peter.loewe@gmx.de>:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 558 1 439
area 0 0 0
all 558 1 439
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 558 1 439
area 0 0 0
all 558 1 439
'report' mode of v.category ignores 'layer' parameter. By default all
available layers are reported, in your case the map contains only one
layer.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
layers
Component: Vector | Version: svn-develbranch6
  Platform: All | Cpu: OSX/Intel
Changes (by cmbarton):
  * platform: Linux => All
  * version: 6.3.0 => svn-develbranch6
  * component: Tcl => Vector
  * cpu: x86-32 => OSX/Intel
Comment:
This appears to be a bug in d.vect, not in the TclTk gui. I just tried
this out in the GRASS 6.4 development version from the SVN.
From the command line in an xmon...
GRASS 6.4.svn (Spearfish60_test):~ > d.vect map=archsites@PERMANENT
color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape
type=point,line,boundary,area icon=basic/circle size=5 layer=1 lsize=8
xref=left yref=center llayer=2 cat=1-10
This displays sites with cats 1-10
GRASS 6.4.svn (Spearfish60_test):~ > d.erase
type=point,line,boundary,area icon=basic/circle size=5 layer=2 lsize=8
This displays nothing
The labeling is worse. I can get labels from layer 1 in the GUI, but from
the command line to an xmon, I get...
The process has forked and you cannot use this CoreFoundation
functionality safely. You MUST exec().
Break on
__THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
to debug.
ERROR eof from graphics driver.
Trying to get labels from layer 2 gives me nothing.
I'm trying this with Spearfish, archsites (I've added columns), and the
dbf driver. I'm using a Mac OSX 10.5.5. But this seems to be a cross-
platform problem.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:2&gt;
layers
Comment (by martinl):
Replying to [comment:2 cmbarton]:
well, and archsites@PERMANENT contains some elements in layer 2?
v.category archsites@PERMANENT opt=report
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:3&gt;
layers
Yes. I essentially duplicated the dbf for layer 1 and connected the new dbf as layer 2, so I know it should be OK.
Michael
Duplicating the dbf and connecting it (with v.db.connect) to another
layer, does not create any features on that layer. To do that, you have to
assign category values to features in that layer, with either v.category
or v.digit.
I think there is still a need to a much clearer and more detailed tutorial
on layer handling, as this keeps popping up...
Moritz
or v.digit.
Moritz
You're right. I forgot to do this step.
Michael
layers
Comment (by neteler):
from the command line to an xmon, I get...
> Break on
to debug.
See
http://lists.osgeo.org/pipermail/grass-user/2009-April/050038.html
and
http://developer.apple.com/mac/library/technotes/tn2005/tn2083.html#SECDAEMONVSFRAMEWORKS
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:4&gt;
layers
Reporter: ploewe | Owner: grass-dev@…
Keywords: gis.m database query | Platform: All
      Cpu: OSX/Intel |
Comment(by kyngchaos):
I think the database problem ultimately boils down to displaying text with
FreeType, as Michael found.
The error means what it says. It comes from FreeType when the old-mac-
fonts options is enabled, and there is nothing that FreeType can do to
"fix" it, because old-mac-fonts means it needs to use Core Foundation.
The real solution is that programmers using FreeType on OS X 10.5 need to
do as the error suggests, exec() after fork(). This forum topic at Apple
describes it concisely:
http://discussions.apple.com/message.jspa?messageID=7875639
The quick solution is to build FreeType without old-mac-fonts. But there
are many with an investment in old Resource-fork based fonts (mainly
PostScript) and this is not a good solution ($$ to upgrade to OTF).
The problem doesn't seem to occur in OS X 10.6. I don't know why. Maybe
Apple saw that so many had problems with this and reverted, or at least
dropped the error (they probably still recommend fork + exec).
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:5&gt;
layers
      Cpu: OSX/Intel |
Comment(by mlennert):
I think the FreeType issue is a different issue than that reported by the
OP.
Concerning this original problem, we still do not have any information of
whether the maps displayed actually had any category values in layer 2 (as
Martin pointed out: archsites in spearfish does not have any info on layer
2). And in the case of the OP, just because one connects a map with
v.db.connect on another layer, this does not mean that the map actually
has any info on that layer.
The following works for me
v.category archsites option=add layer=2 output=myarchsites
d.vect map=myarchsites@user1 color=0:0:0 lcolor=0:0:0 fcolor=170:170:170
display=shape type=point,line,boundary,area icon=basic/circle size=5
layer=2 lsize=8 xref=left yref=center llayer=1
layer=2 lsize=8 xref=left yref=center llayer=1 cat=1-10
In my eyes this bug can be closed as worksforme, and if there is an issue
with FreeType on Mac, please open another bug.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:6&gt;
layers
      Cpu: OSX/Intel |
Comment(by cmbarton):
For the record, when I verified the layer problem, I used a special
version of archsites that I'd modified for testing and teaching. It does
have information in layer 2.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:7&gt;
layers
      Cpu: OSX/Intel |
Replying to [comment:7 cmbarton]:
> Hi,
Ok. Can you still reproduce the issue, i.e. by following my steps above ?
When you said
>d.vect map=archsites@PERMANENT color=0:0:0 lcolor=0:0:0
fcolor=170:170:170 display=shape >type=point,line,boundary,area
icon=basic/circle size=5 layer=2 lsize=8 xref=left yref=center >llayer=2
cat=1-10
the first thing I would test is v.category archsites@PERMANENT
option=report, just to make sure that there are cat values 1-10 on that
layer. Just to be sure we agree: the above line should only show the
circles, nothing else, or ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:8&gt;
layers
      Type: defect | Status: closed
Resolution: worksforme | Keywords: gis.m database query
Changes (by marisn):
  * status: new => closed
  * resolution: => worksforme
Comment:
Tested with current 6.4.3 SVN. All features are rendered correctly
according to their levels.
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:9&gt;
