[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
At the moment, Travis only builds GRASS without running any tests. The
tests should be running on Travis for each commit and there should be
notifications on the list whenever a commit breaks the tests.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771&gt;
Resolution: | Keywords:
Comment (by neteler):
Patches would be gratefully accepted!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:1&gt;
Comment (by pmav99):
Well for starters, #3769 needs to be merged.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:2&gt;
Running tests on CI doesn't really make sense if you have failing tests:
http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
So the next step should be to make the tests pass.
- Ideally, the failing tests should be fixed.
- If that is not possible the tests should be marked as expected to fail.
- If that is not possible then I would suggest removing them for now +
opening an issue to re-add them when they are fixed (one issue per removed
test)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:3&gt;
Comment (by sbl):
Replying to [comment:3 pmav99]:
To my knowledge, most of the tests that are currently failing, started
failing due to fundamental changes from the introduction of Python 3, e.g.
everything related to bytes vs. strings...
So we would have to sort out those from tests that are failing for other
reasons...
> So the next step would be to make the tests pass.
In general +1, but again, lets try to distinguish Pythen 3 related test
failure from all others...
Currently, somehow, most failing tests tell us how far we are from Python
3 (and 2) support...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:4&gt;
Replying to [comment:4 sbl]:
If you scroll down far enough
[http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
here] there is this graph:
[[Image(http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/files_successful_plot.png)]]
Last September, indeed, there was a spike of failing tests but still ~10%
of the tests were practically always failing.
That being said, supporting both Python 2 and 3 is a requirement
encountered primarily in libraries, not applications. Applications usually
only need to support a single Python version. GRASS does provide an API,
but, at least from where I stand, it is primarily an application.
Nevertheless, the decision that GRASS 7.8 will support both Python 2 and 3
has been made and unless it is revoked, the code needs to support both
versions.
Nowadays, there is a great deal of experience in the Python community WRT
both porting code from Python 2 to 3 and to supporting both Python
versions from a single codebase. The latter usually involves using
projects like [https://pypi.org/project/six/\] and/or [https://python-
future.org/]. Using them is of course not mandatory. Most projects only
need a small part of their functionality, so they can often get away with
just a [{{compat.py}}} module and appropriate imports. On projects of
significant complexity though, it is often a good idea to use them.
Long story short, it is indeed more difficult to maintain a cross-version
compatible codebase but with some concessions it is an achievable goal.
In my humble view, the fact that the tests are failing doesn't have to do
with with Python 2 or Python 3 or even with the cross-version
compatibility. There are two rules that are pretty much unanimously
accepted in the software development industry:
1. Don't break the build.
2. You break the build, you fix it.
(obviously, running the tests is considered part of the build)
The afore-mentioned graph shows that GRASS devs don't run the tests as
part of their development routine. I argue that this needs to change.
Arguably, no one wants to wait for a long running testsuite to finish. And
that's absolutely natural. Honestly speaking, no one ''should'' have to
wait. That's what CI is for. To build the code and run the tests.
The gist of the issue here is supporting GRASS' growth. Automated builds
and improved testing procedures are a prerequisite of this goal. An
important checkpoint in this effort is achieving a green build.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:5&gt;
Comment (by sbl):
In principle, fully agreed on all points regarding tests.
Just to add some history. Python 3 support was to a significant amount
worked on in a GSoC project in 2018
(https://lists.osgeo.org/pipermail/soc/2018-August/004186.html), although
that was a big step forward, open issues remained. And after that project
finished, a decision had to be made to either merge the unfinished code
(leading to failing tests) or wait and risk that merging the code later
would become harder and harder. Decision was made for the latter (see
r73229).
Comparing test results before and after this commit (2018-09-02 vs.
2018-09-03) can give an idea about failing tests because of introduction
of Python 3 vs. other failures:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-09-02-07-00/report_for_nc_basic_spm_grass7_nc/testsuites.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-09-03-07-00/report_for_empty_xy_all/testsuites.html
So, making tests pass is a matter of resources (time) I guess, and I am
sure contributions are more than welcome. The question is, what is the
best way forward. Suggestions fromm my side would be to:
   * **Make the test suite and test coverage a topic for a community
sprint**. If those who know the test suite well could help others (like
me) to improve their procedures that would be really cool and appreciated.
   * **Prioritize move to git** if that helps people like you, Panos, to
contribute and help with Python 3 support (which is supposed to be a focus
for the 7.8 release) Really good to see your recent activity here, BTW!
   * **Crack down on the other 10%** of failing test (fix or deactivate
temporarily if necessary as you suggest)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:6&gt;
Comment (by sbl):
Another relevant issue are test datasets, it seems.
Some maps used in tests are not available in all sample data used for
testing (or with different names. If I remeber correctly, some effort has
been put on this relatively newly, as e.g. maps are copied to the correct
name used in the testsuite, before tests are run.
For example, in db/db.copy/testsuite/test_dbcopy.py the map "zipcodes" is
used, which is available in nc_basic, while a suitable map in nc_spm_08 is
named zipcodes_wake, the demolocation does not have a comparable map. The
documentation suggests to use nc_spm dataset for testing
(https://grass.osgeo.org/grass76/manuals/libpython/gunittest_testing.html).
Should tests (where necessary) be updated to work with nc_spm? (or should
input map names be chocen based on name of the location a test is ran in)?
I also had a look at how to skip tests (e.g. if maps are missing in the
location used to run tests). But could not figure out haow to do that.
Hints are welcome!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:7&gt;
@sbl Skipping tests can be with
[https://docs.python.org/2/library/unittest.html#skipping-tests-and-
expected-failures this]. I haven't really tested how it works with
gunittest, but my guess is that it should work out of the box.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:8&gt;
Comment (by sbl):
Some updates after a first attempt at fixing failling tests.
The tests test_v_in_pdal_basic and test_v_in_pdal_filter should be
probably moved from ./vector/v.in.lidar to ./vector/v.in.pdal However,
tests should only be executed if the module is compiled and avaialable
(does not seem to be the case for v.in.pdal). The latter is implemented in
r74287.
Tests with issues with input data, where values changed (possibly also
because of changed input data):
  - ./vector/v.in.lidar – mask_test
  - ./vector/v.univar – v_univar_test
  - ./raster/r.basins.fill/testsuite/testrbf.py
  - ./vector/v.surf.rst – test_vsurfrst (elev_points is 3D)
  - ./lib/python/gunittest – test_assertions_vect (column GLEVEL in map
schools is not numeric)
  - ./imagery/i.vi/testsuite/test_vi.py
Bugs (suffix gets messed up):
  - ./raster/r.horizon/testsuite/test_r_horizon.py
Failing tests due to changes in functions:
  - ./lib/python/temporal –
unittests_temporal_raster_conditionals_complement_else
Test with various issues failures (many of the temporal tests should be
fixed by making functions accept unicode in r74285 and r74286)
  - ./scripts/g.extension – test_addons_modules
  - ./lib/python/pygrass/raster/testsuite/test_history.py
  - ./lib/python/pygrass/modules/testsuite/test_import_isolation.py
  - ./temporal/t.vect.algebra/testsuite/test_vector_algebra.py
  - ./temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
  - ./temporal/t.rast.accumulate/testsuite/test_accumulation.py
  - ./temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
  - ./temporal/t.rast.algebra/testsuite/test_raster_algebra.py
  - ./temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
  - ./temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.sh
  - ./temporal/t.rast.accdetect/testsuite/test_simple.py
  - ./temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.reverse.sh
./lib/python/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py
Tests where encoding is a problem:
  - ./temporal/t.info
  - ./vector/v.what – test_vwhat_layers does not fail on my system, maybe
related to the locals on the server that runs the tests...
Tests where expected output changed from string to unicode
  - ./lib/python/temporal/testsuite/test_temporal_doctests.py
  - ./lib/python/pygrass/vector/testsuite/test_pygrass_vector_doctests.py
  - ./lib/python/pygrass/raster/testsuite/test_pygrass_raster_doctests.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:9&gt;
@sbl Great work!
Replying to [comment:9 sbl]:
r74287.
You are right that the {{{test_v_in_pdal_*}}} should be moved to
{{{./vector/v.in.pdal/}}}. The cause for this was my mistake in #3792
(last two lines of the suggested fix).
WRT skipping the tests, I believe that you can also apply the {{{skipIf}}}
decorator directly to the Testsuite. That being said, if possible,
building on Travis should enable and test optional configurations too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:10&gt;
Comment (by sbl):
I think I can fix the g.extension issue tonight.
However, for the tests failing because of issues with the input data, it
would be really useful to get access to the
nc_spm_full_v2alpha
location.
Unfortunately, I have not found it for download...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:11&gt;
Replying to [comment:11 sbl]:
> nc_spm_full_v2alpha
> location.
Dataset now packaged and published by wenzeslaus:
http://fatra.cnr.ncsu.edu/data/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:12&gt;
Changes (by pmav99):
* Attachment "testsuite.patch" added.
Thank you @wenzeslaus
@everyone
I used the attached patch to get the testsuite runner to use the new
dataset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:13&gt;
I have updated the gunittest docs in r74316 to also mention Travis-CI and
the new sample dataset.
Replying to [comment:13 pmav99]:
dataset.
Patch commited in r74316 (after shallow local testing), thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:14&gt;
Note 1: Some tests require certain compilation options to be enabled (e.g.
pdal, liblas etc). If support is missing the tests are failing. Ideally
these tests should be skipped instead.
Note 2: I did run the tests on an ubuntu VM where all the options were
configured (except opencl and dwg). I did get several more failures than
the ones reported
here]. More specifically on my VM:
(SVN revision 74319)
Executed 233 test files in 0:29:16.353563.
From them 194 files (83%) were successful and 39 files (17%) failed.
For comparison, the latest results from the test server are:
(SVN revision 74304)
Executed 233 test files in 0:36:57.428963.
From them 216 files (93%) were successful and 17 files (7%) failed.
I guess that this difference implies that the server is configured in a
specific way which needs to be documented before we can replicate it on
Travis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:15&gt;
At time the "fatra" server no longer runs, it is frozen at date
2019-03-26 03:01:54 74304 nc_spm_full_v2alpha 93% 98%
@vaclav: could you please check? thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:16&gt;
Comment (by sbl):
In [changeset:"74327" 74327]:
#!CommitTicketReference repository="" revision="74327"
fix multirunner.py with Py3; fix #3798; more Py3 fixes see #3771
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:17&gt;
Comment (by sbl):
Now multirunner also works with Python 3 and tests for P2 and P3 are more
or less even...
However, a new issue pops up:
NameError: global name '_' is not defined
Also, in Py3 I had to deactivate the following tests as the cause
multirunner to freeze...
lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:18&gt;
