[GRASS-dev] [GRASS GIS] #3774: lib/gis/testsuite/test_parser_json.py are failing
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
The tests on {{{lib/gis/testsuite/test_parser_json.py}}} are failing both
on Python 2 + 3.
- [{'param': 'input', 'value': 'hospitals'},
+ [{'param': 'input', 'value': 'hospitals@PERMANENT'},
The tests are also using {{{simplejson}}} which is 3rd party
lib and needs to be installed. I would advise changing that to {{{json}}}.
A simple {{{s/simplejson/json/g}}} should do it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"74162" 74162]:
#!CommitTicketReference repository="" revision="74162"
test_parser_json.py testsuite: use json instead of simplejson (fixes
#3774) (contributed by pmav99)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:1&gt;
Comment (by neteler):
Thanks for catching this.
Replying to [ticket:3774 pmav99]:
... this code I didn't find. Where is that located?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:2&gt;
Comment (by pmav99):
@neteler yes, I am sorry, I should have elaborated a bit more.
That was the output of the tests that show the differences between
expected and actual output. The lines that throw the errors are 46 and 74.
I don't feel comfortable suggesting a fix here, because I am not familiar
enough with fully qualified map names and their nuances. In other words I
can't really judge if the error is in the test itself or in the tested
code. But the test is failing and needs to be fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:4&gt;
Changes (by sbl):
* status: reopened => closed
Comment:
Just ran the test locally:
bin.x86_64-pc-linux-gnu/grass77 -c ./demolocation/stefan --exec python
./lib/gis/testsuite/test_parser_json.py
and it passed without error, both with demolocation and nc_spm_08_grass7.
Closing the ticket, feel free to reopen if needed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:5&gt;
