#3779: quadruplicated definition of "do_doctest_gettext_workaround()"
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
{{{do_doctest_gettext_workaround()}}} is being defined 4 times in the
codebase.
AFAI can tell, apart from the {{{docstrings}}} there are no differences
whatsoever.
$ ag 'def do_doctest'
gui/wxpython/tools/build_modules_xml.py
33:def do_doctest_gettext_workaround():
gui/wxpython/core/utils.py
1155:def do_doctest_gettext_workaround():
gui/wxpython/core/toolboxes.py
774:def do_doctest_gettext_workaround():
lib/python/gunittest/utils.py
35:def do_doctest_gettext_workaround():
{{{lib/python/gunittest/utils.py}}} seems like the most reasonable place
to keep this definition. The other definitions should be removed and the
imports in the gui library should be updated. The docstring at
{{{gui/wxpython/core/toolboxes.py}}} is the most informative one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3779>
