[GRASS-dev] [GRASS GIS] #378: g.region: weird w if input e=w
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
In a latlon location specifing e=w gives a weird w border. E.g.:
$ g.region e=180 w=180 n=90 s=-90 -g
n=90
s=-90
w=180
e=540
nsres=0.00083333
ewres=0.00083333
rows=216000
cols=432000
cells=93312000000
Ticket URL: <http://trac.osgeo.org/grass/ticket/378&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by neteler):
540 - 180 = 360
That's the global wrap-around magic, AFAIK not blocked to allow for the
Mars coordinate system which is from 0..360 deg. Or an epsilon issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/378#comment:1&gt;
Comment (by hamish):
It is ambiguous, do you want 0 columns or 360? What is the goal?
g.region -p says:
e 180E
w 180E
anyway I think that it handles the ambiguous input as best as can be
expected, I don't see the problem here. Possibly throw an error message
out complaining that it has to guess what you meant, but as there cannot
be 0 columns, the only valid choice is the 360 case.
A bug would be if the global wrap around magic fails with e>360.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/378#comment:2&gt;
Comment (by msieczka):
Replying to [comment:2 hamish]:
In a projected or xy CRS e=w or n=s in g.region makes it print an error:
ERROR: Invalid region: East must be larger than West
and quit not touching the region setting. In a geodetic CRS however no
such such error crops out, while it should IMO.
Ticket URL: <http://trac.osgeo.org/grass/ticket/378#comment:3&gt;
  Priority: normal | Milestone: 6.4.0
Resolution: | Keywords: g.region
Changes (by martinl):
  * keywords: => g.region
  * priority: major => normal
Comment:
Any reason to leave the ticket open?
Ticket URL: <http://trac.osgeo.org/grass/ticket/378#comment:4&gt;
Reporter: msieczka | Owner: grass-dev@…
Component: Projections/Datums | Version: svn-develbranch6
Keywords: g.region | Platform: All
      Cpu: All |
Changes (by hamish):
  * component: Default => Projections/Datums
Ticket URL: <https://trac.osgeo.org/grass/ticket/378#comment:5&gt;
