#3788: Bug for flag `-n` in r.lake.series
Reporter: Nikos Alexandris | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: r.lake.series | CPU: Unspecified
Platform: Unspecified |
Panos (pmav99) spotted a bug in line https://trac.osgeo.org/grass/browser
/grass-addons/grass7/raster/r.lake.series/r.lake.series.py#L193: it will
never be True because line https://trac.osgeo.org/grass/browser/grass-
addons/grass7/raster/r.lake.series/r.lake.series.py#L188 redefines `flag`
to be an empty string.
ps- @Vaclav, I can fix this since I can commit to SVN.
File
"/home/baharmon/.grass7/addons/scripts/r.lake.series", line
225, in <module>
sys.exit(main())
File
193, in main
flags += 'n'
TypeError: unsupported operand type(s) for +=: 'dict' and
'str'
Type: defect | Status: closed
Resolution: fixed | Keywords: r.lake.series
Comment (by Nikos Alexandris):
I admit, I had seen two other "weird" lines in the script:
if 'n' in flags:
flags += 'n'
but due to work overload lately, I forgot to fix'em.
After https://trac.osgeo.org/grass/changeset/74431, the module works for
me, from inside the `nc_basic_spm_grass7` Location:
r.lake.series elevation=elevation_int output=r.lake.series.output
start_water_level=150 end_water_level=
156 water_level_step=1 coordinates=637500.000000,221750.000000 --o
produces the following valid raster maps
r.lake.series.output_150.0
r.lake.series.output_151.0
r.lake.series.output_152.0
r.lake.series.output_153.0
r.lake.series.output_154.0
r.lake.series.output_155.0
r.lake.series.output_156.0
Try again please.
ps1- It seems that `t.list strds` is broken here. Will verify.
ps2- This is why automatic tests are a necessity to run after each and
every commit.
