#3789: migrate trac to github
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: svn, git, migration | CPU: Unspecified
Platform: Unspecified |
This issue is open for discussion. Note that any kind of migration hasn't
been yet decided by GRASS PSC. See also related #3722.
Code used for migration source:grass-addons/tools/svn2git/trac2github.php
Links below point to a first attempt, only issues with milestone set to
8.0.0 have been migrated in order to allow first public review.
PLEASE HELP WITH REVIEWING this draft migration (tickets, labels
reorgranization, check if your github account is properly linked in https://trac.osgeo.org/grass/browser/grass-
addons/tools/svn2git/trac2github.cfg#L19)
Bearing in mind that probably only G7+ issues will be migrated, it's still
a big number:
8.0.0+7.8.0+7.6.1+7.4.5+7.2.4+7.0.7
42+32+325+48+144+163 -> 754
PLEASE HELP TO REDUCE NUMBER OF OPEN ISSUES! Some of them are outdated,
probably already fixed... Public review is very welcome, thanks!
BTW, we should probably start marking older releases by !EndOfLife term to
be clear than no other releases are planned. What about keeping only two
last release branches active. So:
* 7.6.1 planned
* 7.4.5 planned
* 7.2 EOL (no 7.4.5 is planned)
* 7.0 EOL (no 7.0.7 is planned)
Then we could change milestone of all EOL tickets to 7.6.1. (or 7.6.2)
Replying to [comment:2 martinl]:
+1! Don't be shy, please check the open bug reports here.
to be clear than no other releases are planned. What about keeping only
two last release branches active. So:
> * 7.6.1 planned
> * 7.4.5 planned
> This should be done ideally before migration.
... not sure if they must be reduced to exactly 0 open bugs/wishes prior
to !GitHub migration but still some relevant bug reports may wait for us
in these two lists. Please update them, along with incrementing the
milestone to >= 7.4. Thanks!
