GDAL
1
#379: g.mapsets: unwanted mapset duplication with add= parameter
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The following undesired duplication effect happens:
GRASS 6.4.svn (slovakiaUTM24):~ > g.mapsets -p
PERMANENT modisLST005filt modisLST005filt2
GRASS 6.4.svn (slovakiaUTM24):~ > g.mapsets add=modisLST005filt2
modisLST005filt2 PERMANENT modisLST005filt modisLST005filt2
A fix would be appreciated.
Ticket URL: <http://trac.osgeo.org/grass/ticket/379>
GDAL
2
Reporter: neteler | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
The attached path should fix the bug. Any objections to introduce new
function to gislib?
G_is_mapset_in_search_path()
Ticket URL: <http://trac.osgeo.org/grass/ticket/379#comment:1>
GDAL
3
Comment (by martinl):
Patch applied in trunk (r35449). Any objections to backport to devbr6 and
relbr64?
Ticket URL: <http://trac.osgeo.org/grass/ticket/379#comment:2>
GDAL
4
Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:2 martinl]:
and relbr64?
Done in r35539 and r35540. Ticket closed, any testing welcomed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/379#comment:3>
