#3793: r.info non - numeric result for Total cell count on large raster
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.1
Component: Raster | Version: svn-
Keywords: r.info non - numeric result for | releasebranch76
Total cell count | CPU: x86-64
Platform: MSWindows |
I have a raster that is 110000 cells by 124723 cells. When I run r.info
on the raster, the result Total cell value is a non-numeric result ( see
below )
r.info map=Capefear_basin_CFS_area_dem05@capefearsh
| Map: Capefear_basin_CFS_area_dem05 Date: Thu Mar 14 13:12:37 2019
| Mapset: capefearsh Login of Creator: dnewcomb
| DataBase: C:\Users\dnewcomb\Desktop\grass
| Title: Capefear_basin_CFS_area_dem05
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: FCELL
| Rows: 110000
| Columns: 124723
| Total Cells: ju
| Projection: NAD83(2011) / North Carolina (ftUS)
| N: 1020000 S: 470000 Res: 5
| E: 2220000 W: 1596385 Res: 5
| Range of data: min = -134.404 max = 1101.429
| Data Description:
| generated by r.mapcalc
| Comments:
| all_capefearsh_05_counties@capefearsh * 1
Component: Raster | Version: svn-releasebranch76
Resolution: | Keywords: r.info non - numeric result for
| Total cell count
CPU: x86-64 | Platform: MSWindows
Comment (by mmetz):
Unfortunately this is not reproducible (on Linux). What do you get with
shell-style output, i.e.
| Total cell count
Comment (by dnewcomb):
Running with shell style output gives the correct answer.
| Total cell count
Comment (by mmetz):
In [changeset:"74265" 74265]:
#!CommitTicketReference repository="" revision="74265"
r.info: sync formatting of total cells, see #3793
| Total cell count
Comment (by mmetz):
In [changeset:"74266" 74266]:
#!CommitTicketReference repository="" revision="74266"
r.info: sync formatting of total cells, see #3793 (backport trunk r74265)
