2008/2/10, Glynn Clements <glynn@gclements.plus.com>:
> > > FWIW, on my system (Debian/stable) there is no python-config in sight.
> > > $ locate python-config
> > > $ apt-file search bin/python-config
> > > nothin.
> > > (apt-file searches all packages in the entire Debian(/stable) archive)
> > > renamed?
> > python-config is part of *python-dev* package (only Debian
> > testing/unstable, it is not included in Etch). I don't know about
> > Mac/Windows Python distribution.
And if you don't have python-dev, you won't be able to build python
extensions for more fundamental reasons than the lack of
python-config.
> on Etch
> python2.4-dev: usr/bin/python2.4-config
> python2.5-dev: usr/bin/python2.5-config
[Does it create symlinks? Anything created by a post-install script
won't be visible from apt-search.]
It is true for Debian testing/unstable not for Etch(stable). There is
no python-config.
In any case, that's why we need to allow e.g.
--with-python=python2.4-config
> I will upgrade configure to check also for python${PYVERSION}-config.
Where are you going to get ${PYVERSION} from before you've located the
python-config program? If there is more than one version installed,
invoking "python" won't necessarily use the right version.
Python version is determined from small python script(s).
1656 # find out python version
1657 AC_MSG_CHECKING(Python version)
1658 PYVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[:3]'`]
1659 PYMAJVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[:1]'`]
1660 PYMINVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[2:3]'`]
1661 AC_MSG_RESULT($PYVERSION)
1662 AC_SUBST(PYVERSION)
I didn't change this part of configure script.
The problem with python-config is that there is *no* version switch.
Usage: /usr/bin/python-config
[--prefix|--exec-prefix|--includes|--libs|--cflags|--ldflags|--help]
So how to determine python version using python-config?
You can currently run with --with-python=/usr/bin/python2.5 to force
using version 2.5.
Resist the temptation to turn configure into an expert system. The
general policy is that any deviation from the obvious default has to
be explicitly specified by the user.
E.g. any headers which aren't in the system include path require the
corresponding --with-includes= switch, regardless of how common a
particular setting is.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
