[GRASS-dev] [GRASS GIS] #38: configure.in: wxwidgets and python checks
On Feb 5, 2008, at 9:48 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Tue, 05 Feb 2008 15:33:16 -0000
Subject: [GRASS-dev] [GRASS GIS] #38: configure.in: wxwidgets and
  python checks
To: undisclosed-recipients:;
Message-ID: <041.9c4978075f370c9d8e8e1cc30c0cf3f1@osgeo.org>
Content-Type: text/plain; charset="utf-8"
Reporter: martinl | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
I modified the configure script to support wxWidgets. It checks
  * if wx-config is presented
  * wxWidgets version (>=2.8.1 required)
  * check for wx/wxprec.h and wx/wxPython/pseudodc.h (wxPython required
too)
The patch also checks for Python.h header if --with-python is given.
This should solve compilation of wxGUI vdigit component
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/vdigit/Makefile.in
Martin
Martin,
Is this the main GRASS configure script or just a script for vdigit?
If the former, this could be a problem on a Mac, depending on how it searches for stuff. I don't think that wxWidgets is installed on a Mac along with wxPython. This is different on Linux machines. Also, as William mentioned yesterday, Python on a Mac is in a different place than it is for Linux--and in yet a different place for Windows.
Michael
Michael,
2008/2/5, Michael Barton <michael.barton@asu.edu>:
yes, the "main" configure script (./configure). There no "local"
configure scripts. The patch adds new switch --with-wxwidgets to the
configure.
Regards, Martin
Michael
grass-dev mailing list
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
What does --with-wxwidgets do if you set it? What happens if you do not?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
On Feb 5, 2008, at 10:11 AM, Martin Landa wrote:
Michael,
configure.
Regards, Martin
Michael
grass-dev Info Page
-- Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
from the ticket description
It checks
    * check for wx/wxprec.h and wx/wxPython/pseudodc.h (wxPython required too)
for vdigit it meas: it is compiled only when you give --with-python
and --with-widgets, otherwise vdigit would be not compiled.
Martin
Michael
Phone: 480-965-6262
Fax: 480-965-7671
> Michael,
> configure.
> Regards, Martin
>> Michael
>> _______________________________________________
> ~landa *
On Feb 5, 2008, at 10:24 AM, Martin Landa wrote:
It checks
Martin
That's fine Martin. Thanks. I'm trying to find out how it checks. Are the checks generic enough to work with Mac and Windows, or are they still hard coded to Linux locations?
Michael
Michael
Phone: 480-965-6262
Fax: 480-965-7671
Michael,
configure.
Regards, Martin
Michael
grass-dev Info Page
~landa *
>> do not?
> It checks
> required too)
> Martin
if you look at gui/wxpython/vdigit/Makefile, only one location is
still hard-coded, the includes for python
-I/usr/include/python$(PYTHONVERSION)
The patch checks for Python.h and include directory, it should work on
Mac/Windows too.
Martin
On Feb 5, 2008, at 10:45 AM, Martin Landa wrote:
do not?
It checks
required too)
Martin
Mac/Windows too.
Martin
OK, my standard MacPython include directory and Python.h are at /Library/Frameworks/Python.framework/Versions/2.5/include/Python.h
wx is down a similar path.
Michael
On Feb 5, 2008, at 11:45 AM, Martin Landa wrote:
Mac/Windows too.
Martin
This is not good. Unless the --with-python include dir is also used. (RE my suggestion from the GDAL configure) I don't see anything in configure that sets a python include dir. In fact, I don't see the wxwidgets option either - are you sure it's in SVN now?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
Hi
2008/2/5, William Kyngesburye <woklist@kyngchaos.com>:
[snip]
the patch is attached to the ticket, see
http://trac.osgeo.org/grass/attachment/ticket/38/configure_wx.diff
not submitted to svn, since the review is needed...
Martin
Mac/Windows too.
Martin
The basic idea is sound -- do a check at configure to see if the resources are present to compile vdigit and set it to compile or not compile accordingly.
We just need to make this generic enough to encompass the cross-platform variation in Python installations.
Michael
Ah, I see. Somehow I assumed that it was SVN already...
Looks good for OSX, though I'm not comfortable rebuilding configure from configure.in to be able to test it.
On Feb 5, 2008, at 12:03 PM, Martin Landa wrote:
Hi
[snip]
Martin
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
Martin Landa wrote:
> >> do not?
> > It checks
> > required too)
> > Martin
You should probably use python-config to get this information.
I would suggest that --with-wxwidgets and --with-python take optional
arguments specifying the path to the wx-config and python-config
utilities respectively, in case they aren't in the path. --with-gdal
already behaves like this.
Also, is there any need to have vdigit/Makefile generated from
Makefile.in. Can the configuration settings not go into
Platform.make[.in]? vdigit/Makefile already includes Platform.make via
Lib.make.
Mac/Windows too.
The configure checks might work, but the hard-coded linking switches
and ".so" won't work. I suggest trying to mimic a normal library build
as closely as possible.
