[GRASS-dev] [GRASS GIS] #3801: r.watershed crashing on large rasters
Reporter: dnewcomb | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.6.1
Component: Default | Version: 7.4.1
Keywords: | CPU: x86-64
Platform: Linux |
Attempting to run r.watershed on a 13.7 billion pixel raster elevation
layer
  r.watershed --overwrite elevation=cfsdem05 accumulation=cfs_accum
drainage=cfs_drain
SECTION 1a (of 4): Initiating Memory.
WARNING: Subprocess failed with exit code 11
WARNING: category information for [cfs_accum] in [PERMANENT] missing or
          invalid
WARNING: category information for [cfs_drain] in [PERMANENT] missing or
          invalid
I have tried this with Memory=100000 MB
Does r.watershed need more than 100GB of memory to run on a 14 billion
pixel raster?
The raster is linked via r.external, doe it need to be imported ?
Looking backwards, the enhancement to run large raster was done for GRASS
7.0 , is this a regression, or was it not tested to larger than 9 billion
cells?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3801&gt;
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [ticket:3801 dnewcomb]:
layer
drainage=cfs_drain
> invalid
> invalid
The memory option has an effect only when using the -m flag. I don't think
r.watershed in all-in-memory mode (no -m flag) is supporting such large
input maps.
pixel raster?
GRASS 7.0 , is this a regression, or was it not tested to larger than 9
billion cells?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3801#comment:1&gt;
